OK guys,
Through the years Bosch made changes to the injectors. I believe too that injectors besides size and flow rate in lbs... What is the mass-flow rate of a stock injector? Any way i can just order up a new bosch set through Ford for a mustang where they are $80 new? How about improvements through the years..
Looks like our injectors are bosch 0 280 155 217 which has a unique impedence of 13.1 where 14.3 is more the norm. 19 lb/hr is the most common flow rate. THe 93+ seem to be 4-hole connector is EV1. There are adapter for the electrical fitting to go from the current EV6 to EV1. So no wiring issue. Just don't know how temperimental the LH computer will be with a impedence change @ injector.
Michael
Michael
