I should explain: Yes, $3k is on the high side. But if you ditch the factory door speakers, you lose quite a bit of bass / bottom end. Getting anything to work properly with the factory door speakers is very difficult (external amps / crossovers, lots of tuning). Adding a power sub in the trunk helps the lower octaves but still leaves a gap in the midbass range in the front soundstage. To do it right, you need custom door panels (like Jehnert) with one or two good 6.5" midbass drivers per door. That alone can be $1k for quality stuff, most people do not have the skillz to fabricate their own doorboards. Quality amps, head unit, labor to install, etc adds up fast.
IMO, a powered head unit driving the dash & rear deck speakers alone, will sound worse than stock. I still think getting the Becker 1432 mod with auxiliary in, and retaining the stock amps & door/rear speakers, with (optional) Rainbows in the dash, is the best bang for the buck. This retains the ability to run the CD changer in the trunk if desired:
http://beckerautosound.com/1432-1991/aux_input.htm
For the record... I have two cars with full Jehnert systems and separate power amps, several cars with all stock speakers & head units, and one 1992 where the head unit was replaced with aftermarket plus power amp feeding the stock door speakers, Rainbows in the dash, etc. The 1992 car sounds the worst, as it doesn't have the impedance correction and equalization built in to the factory amps. MB and Bose did a pretty good job with the factory stuff, and it's easy to make it worse if you're not really careful. YMMV, etc.
With proper design and some knowledge of system architecture, you can put together and very nice sounding system on moderate budget.
On the topic of head units, like I mentioned, go with a high end one that has extensive sound field processing built in, that way you can dial in your sound stage and optimize it for the driver.
Agreed. If you have the experience, you can probably change to aftermarket components on a moderate budget.+1, Although this requires years of experience which most members don't have.
Sadly, no, at the moment Becker does not offer any more modern head unit as plug & play for the 1991-1993 models with 1432 head unit. And that's a real shame. I wish they would come up with a converter box that would allow the newer units to work with the stock amps. It wouldn't hurt to ask them if they have any plans to create an adapter to allow newer head units in place of a 1432, but don't get your hopes up.Does Beckers offer any other more modern plug and play units?
Y'all got that right ... particularly the later (1989-1991) more advanced W126/C126 systems.Also, w126 stock speakers kick 124 speaker butt.
That is plug & play on 1994-up models which had the 1492 head unit from the factory.Becker DTM 7910 what about this? they said it was a plug and play except for the antenna wire? I called them in NJ. $550 for the head unit.
It's hard to say, because I'm not quite sure how he is making it work. I'd like to see the adapter cable. It may be possible, and it may sound good. I've just never seen anyone pull this off yet and report it on the forums, but that doesn't mean someone hasn't done it! And, I would LOVE to know how to do it, if possible.Spoke to Stefan at SW Stereo(www.swstereo.com) a while back as I had a 1432 in my 1992 300SE. He said he could make an adapter that would connect an up to date head unit (like the blaupunkt San Francisco 320 or Toronto 420) without cutting wires, etc. He then would send an antennae extension cable that you would route along the passenger side of the car so the antennae would work correctly.
Is it the general consensus that, even with a solution like this, the end result would not be as good as the factory system?
BTW - the antenna is the easy part, you just add an extension, as he said.
