2.25" for 5.0l, how about 6.0l?
6L V8 2.25" to 3" will still support the power. Even though it's 1L bigger displacement you need to calculate how much air volume is moving in and out at a given RPM and temp.
The issue is if you go too big of a pipe all you get is deep tone and no torque with minimal hp gains up top.
If the pipe is too small you get a mid tone alot of velocity giving nice mid range but a drop in rpm.
there is still an art in exhaust design but with newer cars most exhausts are free flowing and there is probably a 10% improvement factor. On older cars before 2005 there is a good 20-30% improvement factor on exhausts.
You have to also take the muffler into account, alot of companies boast "Hi-Flow", "straight through", "low restriction". In a perfect world of more flow = more power is true to a point. Universal mufflers are what they are universally offering one thing.. More Flow.
Mufflers should be used for two things...
1. Controlling exhaust velocity
2. controlling sound
A muffler can be used to speed up or slow down exhaust gasses by playing with hi/low pressure chambers. This is a whole different discussion on it's own and really not worth discussing unless you plan on building a muffler can from scratch.
But for a 6L a good setup would be 2.25" per bank X pipe it with a 3" mid section exiting to dual 2.25" entering mufflers. So basically you are utilizing dual 2.25" from the manifold to the tail pipe which flows roughly like a 3.75" or 4" pipe.
If you do a dual 2.5" pipe then to a 3" you deal with the low speed/high speed section again which affects mid range torque delivery.
But realistically 5.0L and 6.0L 2.25" to a 3" vs 2.25" all the way back i would speculate 3-5% horsepower difference (positive direction) about 5% torque difference (negative direction)
In my opinion the stock exhaust looks kind of Camry.
Hey my company car is a Camry all i do is turn the key and it keeps going...
But yes stock exhaust is not something to brag about. But big chunky tips looks odd to me..
i will revisit the tip option again once we get something fitted and check numbers.
BTW anyone have a STOCK 500E Dyno plots... the car i am working with has a Golf ball hole in several sections of the muffler. So if i were to dyno this car the way it is with all the holes it would not properly represent the before and after gains.
