1969 300SEL 6.3 - Burned but salvageable - Ft. Worth Texas - Copart
  • Thread starter Thread starter Bondavi
  • Start date Start date
If this car could be obtained for the right price, it could be a good donor for the powertrain. It's a 1969 model, so unencumbered with emissions crap (my car was also a 1969 model). Starting in 1970 they started putting emissions crap on the cars, including the removal of the distributor vacuum advance mechanism. They also lowered the compression ratio, added emissions-control relays, and gasoline vapor-recovery in the trunk. I always loved the little rubber port set neatly into the rear fender, behind the bumper overrider, on my 1969 car that vented the fuel tank pressure directly to the atmosphere !!
1968 and 1969 cars are most preferable, at least to me. It's too bad to see this, as there are very few viable 6.3s out there these days, but as with our E500Es, every one that goes down, elevates the value of the survivors. Seeing as only 6,526 of the 109.018 model were even made, with perhaps a couple of thousand survivors if that, these cars are really starting to go up in value. I sold my car for $18,000 some 10 years ago, with absolutely no issue.
All this said, the E500E is a far better car than the 300SEL 6.3 in every conceivable way.
I can see a W111 Coupe/Cab conversion..... nice period item, easier than a 119/124 swap I bet.
Ron
Actually it takes some firewall and transmission tunnel work (sound familiar?) to shoehorn an M100 into a W111/112/108/109 chassis. Not to mention the steering linkage has to be redone. It's not an easy job. Unlike the M119, the M100.98X engine is an honest-to-goodness "big block" in the identical vein of a GM or Ford "big block" V-8. It's a massive piece of iron and aluminum and weighs a friggin' TON.
What's a m100 weight?
440 wedge is about 660 lb.
Cummins bt6 is the heaviest thing I've seen @1100 lbs.
M
Pretty damn heavy, I've never used an engine hoist to pull one out, but instead dropped it out from underneath. A 1 ton chain hoist will lift it which is how I got my engines on and off the trailer when I moved buildings.
I used to have a spare 6.3 motor (M100.981) in my garage when I lived in Portland. It was around 750 pounds as a long block. Had it on a pallet.
That was a nice car before it burnt down. It was early Euro and super clean under the hood. The fog lights where Marchal' which I know the classic 911 guys love.
