If the fan is blowing at low speed, but will not change speeds when you press the max / min buttons on the console... most likely the regulator has died. Or, if it only goes between min/low speed and medium-ish, that also indicates a failed regulator.Actually the AC is sort of blowing at low speed. Would someone kindly advise where the 30A strip fuse is located on 1994 E500?
As always, thanks in advance.
that's a junk, no-name part... don't expect a long lifespan.Is this the part: Amazon Part
Now that’s funny!I’m impressed they can even make a part that looks legit for $30.
Found the fuse (great directions, thanks!) and it looks fine. Will test it but it doesn’t appear probable that’s my issue.Go to the fuse box area, and you will see a black cable about the diameter of your pinkey finger. it is about 6" north of the fuse box near the curve of the false fire wall IIRC. It will have a black plastic tubular case to it, open that and there is the fuse.
Do you get any airflow (vs key off)? Trying to figure out if your blower is running on low speed, or not at all.I finally replaced my hearing aid’s consumables so I can hear clearly and listened to my blower. If I hit any buttons that should activate the fan I get a very faint whistle noise. No matter the speed, ac or defrost.
Any ideas before I start tearing things down?
If the fan never turns on, it's the blower / regulator, OR the +12v power to those items.First question: do these updated symptoms point to anything other than blower / regulator?
If the fuse is physically removed, yes.Second: are simple continuity checks adequate for the fuses?
Yes, with inflation and a lot of time since I made the initial "deferred maintenance" prediction many years back, as well as the NLA and difficult parts situation, the new rules are as follows:Gerry, what’s today’s (2024) cost of deferred maintenance? A lot more than 10k if the last single legs now cost $2k.
I don't doubt your estimate one dollar! I read your top-end refresh and almost fainted. I love this car but it's like holding a grenade in one hand and trying to get the pin back in with the other in the dark while walking on a rolling log in a fast moving current.Yes, with inflation and a lot of time since I made the initial "deferred maintenance" prediction many years back, as well as the NLA and difficult parts situation, the new rules are as follows:
<100,000 miles = $20,000 of deferred maintenance
100,000-150,000 miles = $25,000-$35,000 of deferred maintenance
150,000-200,000 miles = $35,000-$45,000 of deferred maintenance
>200,000 miles = $50,000+
** Note that above prices are for dealer labour + MSRP parts prices.
** Independent shop labour can reduce above numbers by 20-25%
** DIY labour + discount factory / quality aftermarket prices can reduce above numbers by 50-60%
If you don't believe me, please check my Top-End Refresh thread (this was just engine bay items) and the amount of time, labour and parts that were required for this. My car at the time had around 140K already well-maintained miles on it. I would put the total parts and labour for my work at $25,000.
If you don't believe that the numbers above are accurate, I am 110% sure that @jhodg5ck and @Klink will be very happy to confirm them, based on real-world experience and their shop pricing.
Sorry but what is meant by mcflaps?your local mcflaps (or radioshack equivalent (i miss them) may have them. AMazon has them and they are better make up anyway. search mini ANL 30a strip fuse for automotive marine
Yes, if you apply 12V directly to the blower motor, it should run at max speed.If I apply 12v power to blower leads should it run?
McParts / FLAPS = Friendly Local Auto Parts Store. Basically any part store chain nearby... NAPA, O'Reilly, AutoZone, Carquest, Pep Boys, etc...Sorry but what is meant by mcflaps? No radio shack near me.
In rare cases, a new blower can kill an old regulator, or so I've heard (never experienced this personally).Drove back to beach this morning. 50 miles later blower stopped blowing. I am gobsmacked. Now what?
Regulator should play no role as new blower worked great albeit for only an hour.
Plan to drive home and rip it all out again this weekend.
How cheap? Don't tempt me, lol!Anyone want a 1994 E500 cheap? Make me an offer.
Is the blower motor completely dead, not running at all (first post) or is it running at low speed only (second post)? These are 2 completely different failure modes.Blower is blowing cool air at one speed - weak.
Gerry, I was reluctant to swap in the new $40 'imported from somewhere other than Germany' regulator. Odd symptoms also added to my conundrum. I can only hope to and learn. Thank you as always for the advice.I recommend strongly that one replace both the blower motor assembly AND the blower regulator (resistor) at the same time. It's best to do both together. And a new fuse, as well.
I did do all the following with everything stationary.
 Standard / expected symptom with a failed regulator.... disassembled to point where I could observe blower. Blower ran only in low speed.
Ignition switch is only suspect when the blower does not run *at all*... zero speed even with good fuse/wiring/etc. Since the blower was running on low speed, the ignition switch is OK.Dicked around with ignition switch, no impact there.
