N
norcal1440
Guest
A fews weeks before reverse stopped working.
The brake light came on and I had to put car
in neutral to start. So can a faulty neutral safety switch or
worn out shifter bushings cause you to not have reverse?
1995 E320 with a 722.369 automatic transmission
Previous owner had transmission rebuilt in 2010 it currently has 50,000 miles on the rebuilt. I'm sure transmission fluid has never been changed since rebuilt. Is there a chance changing the fluid would cure the problem or is the B3 friction plates gone in it.
