I have 2 034 cars that have sticky valves in the valve bodies. One of them the 92 400E will randomly miss the 1-2 up shift only when the kick down solenoid is activated. The other the 94 E420 will randomly neutral out after coming to a complete stop. Shifting into reverse and then back into drive will cure that issue.
So I contacted Sun Valley asking if they sold rebuilt valve bodies or if they would rebuild if I sent mine. Currently they do not offer any components for sale. Only rebuilt units. Also they are so backed up with work so if you need to have a transmission rebuilt there might be extended down time if they don’t have one ready to go.
He did however recommend an additive that has worked wonders for them for random or intermittent issues that I described above. The product is called Prolong Transmission Additive and you can find it on Amazon and possibly Walmart. So if you are experiencing strange intermittent issues with your transmission service it with new fluid and add a bottle of Prolong.
https://www.amazon.com/Prolong-Super-Lubricants-PSL15000-Transmission/dp/B001DKV5H8?
