Did you ever get another valve body?Ah crap that is a bummerTake a deep breath (and enjoy the drink first). Sleep on it, then go back and double check everything. Might be something really simple like fluid level? Blockage in cooler lines?
Yep, bummer... Double checked everything yesterday, no leaks, nothing left disconnected, I've actually cleaned out cooler lines and ran a quart of fresh fluid through them prior to installation.Ah crap that is a bummerTake a deep breath (and enjoy the drink first). Sleep on it, then go back and double check everything. Might be something really simple like fluid level? Blockage in cooler lines?
No, I didn't replace the vale body I just cleaned it out, put all the sections back in their places as per manual (new K1 and K2 spring assemblies)... It almost seem that is the only thing left to try to replace, everything else is pretty much has been done...Did you ever get another valve body?
Sent from my SM-G960U using Tapatalk
I need to check my stash o transmissions but I may have one with a known good VB which I'd say go ahead and test with.Yep, bummer... Double checked everything yesterday, no leaks, nothing left disconnected, I've actually cleaned out cooler lines and ran a quart of fresh fluid through them prior to installation.
I even let the tranny sit with fresh oil for a day, then drained it all out before starting the car to ensure that no accidental unwanted particles are left...
Regards,
D
In the perfect world, yessss!!! In reality, I'm actually re-thinking my entire parking space at the house, and what I think would happen, is this:Sounds like a good decision D. In a perfect world, we'd all have unlimited time and resources to 'tinker'. Since that's not the case, we must all choose wisely.
I'll miss the updates though!
So... Just for shits, went back to those PDF manual, here is the ATSG troubleshooting guide (my issues are in red brackets)Dagnabbit! I really wanted to find out if a different VB would cure the trans...
I think what they refer to as "shift valve housing" may be the VB, but we'd need Klink or Jono to confirm.
You can measure control pressure by connecting a gauge, you remove a plug on the side of the tranny and attach the gauge to view pressures while driving. MB wants you to set the vac modulator using this method but it's far easier to adjust by feel / trial+error test drives. However, in your case the pressures would be helpful. I wonder if the primary pump could be at fault, as you wouldn't have replaced this.
Gotta be SOMEONE out there who has a leftover 2nd gear start VB! How about all those folks who upgraded to FGS VB's?
D, forgot to ask, are all 3 upshifts flaring? Do any result in no upshift at all, or will it eventually get into 4th gear?10 min into the test drive... Back to exactly the same thing what I've started with!!!
10 min on cold transmission - perfect, so happy (was), smooth, quiet, easy shifting. Warmed up, and the very same shit again, revs up, flaring up, not upshifting. Exactly the symptoms it started with before rebuilding the tranny.
If any one could suggest what else could I try after this complete rebuild, not allowing the transmission to upshift when warm, I'd be happy to try something...
I did go through the valve body, no broken springs found, cleaned it all up, replaced K1 and K2 accumulators/springs, could it still be the culprit of the failure?
Tease!!!I have my refreshed Stock 036 VB cleaned and vacuum sealed sitting safely in the climate controlled storage unit, it is not for sale....yet![]()
Dave,D, forgot to ask, are all 3 upshifts flaring? Do any result in no upshift at all, or will it eventually get into 4th gear?
How about downshifts?
Seesms REALLY weird that it shifts perfectly when cold, but terrible after only 10 minutes.
I should think you would finish it if only for mental health reasons after investing that sort of sweat equity in the project. But if it were me I would be putting a 722.6 in with paddle shifters and calling it good.Sooooooo, she is parked on the side of the house, haven't had the balls to start parting her out yet...
Regards,
D
P.S. Topless 5.0L is fun thing to drive
Well, I have the valve body coming my way, I will certainly give it a try, keeping fingers crossed, this would make it drive-able again! 722.6 Would indeed be great, and those can take some serious beating too! Don't have the time or enough "how to" to do something like that.I should think you would finish it if only for mental health reasons after investing that sort of sweat equity in the project. But if it were me I would be putting a 722.6 in with paddle shifters and calling it good...
Regards,
D
If possible, measure what you drained out. Otherwise, as a VERY ROUGH guide, put in 3 quarts and then check the level with the engine running. When cold, the level should at least be on the dipstick, and may be something like 0.5 to 0.75 inches below the MIN mark. If you're lucky, you'll have one of the dipsticks with dual ranges (cold & hot). Assuming you swapped the VB, you may end up adding about 4 quarts to get the level to MAX when fully hot. Remember to only add 1/4 quart at a time, it's easier to add than it is to remove...Dear folks, I'm about to button up the FGS valve body, however, can't find anywhere the fluid capacity without torque converter drain? I know it's 8 quarts at full service, but I didn't bother draining converter (since the fluid is new), just the pain was drained...
I know my was trashed, you've seen the clutches, had to be rebuild, and yet still needed that VB to make it all work!RED DEVIL IS ALIVE!!!!!!!
Thank for the fluids pointers...
I have 1st gear start!!! Imagine that!!! Now, it runs, it drives, it shifts and it chirps tires...
Perfect - no, not yet, its the time to fine tune it via bowden cable, modulator adjustment and may even be via Superior K722A-G kit bits and pieces: upshits a bit too soon, does not want to downshift quickly, however, it does go through all the gears. Driving it while shifting manually up or down is a freaking blast!!!
Thanks maw, will definitely start with the Bowden adjustment! Really looking forward seeing this thing rippin through gears again!Adjust the Bowden cable 2mm tighter, then see her downshift quicker and upshift later. Do that before you even think about shift firmness (modulator). If 2mm is too much, go back to 1mm, if not enough, go to 3mm.
It's quicker, easier, and more effective for your complaints.
Congrats and GL.
P.S. Be aware that if you go too far in the Bowden cable adjustment, you may get a CEL. Those fine tuning amounts are what I learned for the experts here and at Sun Valley Transmission when I did this a few years ago. I know 2mm feels like tiddlywinks, but trust me it's not.
Dave, no idea, old VB puzzles me too, all looked good, I cleaned all out, no broken pieces at all, but that's all in the past...YEAH! Awesome news - congrats! I really, really wonder what was wrong with your old VB... especially since you tore it down & cleaned everything .
Side note: The 1992 400E VB you have (from WDBEA34E2NB672775) is not the original. The part number inked is 124-270-69-15 (minus the 270) and based on the font & format, appears to be from a factory rebuilt transmission. This would make sense as the #69 VB was only used on later .034's (1993-up). Since the round check valve #24 was present, it may have been an upgraded/rebuilt VB based on a 1992 VB. Just a bit of trivia as no 1992 400E left the factory with a #69 VB.
maw is correct, btw, fiddle with the Bowden/control cable adjustment at the linkage behind the airbox to fine-tune the upshift points. As he said, a little goes a long way. Unfortunately you cannot modify the individual shift points (i.e., if 1-2 is early but 2-3 and 3-4 are ok, that is controlled by internal VB wizardry). Based on your description, I think the linkage adjustment may get you where you want to be...
722.3_valve_body
Dave, believe me, thought about, but I remember testing the cable after connecting to the gear box before mounting the VB, and also remember that I mounted it well under the hood, cir-clip and all... But to the "flipped" mounting lever under the hood???...Question: As you are adjusting the Bowden cable at the linkage behind the airbox, are you getting ANY change in upshift RPM's? If not, I think your Bowden cable is not properly attached to the small L-shaped rod inside the transmission...
Cheers maw!
Very happy to have this resolved, and very happy that it's not another part out.
Dad, well, he loves the looks of R129, and after I got this one to run, asked if he would like to have it if I restore it completely. Unfortunately he can barely get in and out of this car, mom can't even do that (ex nurse, spine is shot) Just not for them. Nevertheless, anytime I work on the cars, their place or mine, paps always tries to help or just brings his comfy folding camping chair, sits down cheers for good results.
I bought him and mom a Deville few years back, he loves it it's comfortable and well suited for both of them. He says it's perfect for "old people" so this red devil is mine after restore.
Regards,
D
I can lol and now that I think back, I know exactly how it happen! One night was cold was wearing thick coat while tightening down the bell housing bolts/nuts, sleeve must have pushed it backwards...I can’t believe that you could mess something like that up! I mean the throttle linkages on these things are just SOOO straightforward!...
I believe 7/8/9/10 gears in transmission is primarily to help mfr's hit government-mandated fuel economy requirements....I can’t figure out why anyone cares about these 7-9 speed gear boxes. Yes, I can see why not 4. But more than 6, I don’t get. It’s just more gears to bypass when downshifting.
Completely agree. Our 2011 A4 with 8 forward speeds drives me nuts. Constantly hunting to find the right gear.I believe 7/8/9/10 gears in transmission is primarily to help mfr's hit government-mandated fuel economy requirements.
There's a side benefit of the extra gears slightly improving straight-line performance, as it keeps the engine in the peak powerband for longer periods of time.
But in general, all them gears are definitely not enhancing the driving experience.
Warmed up the car, and a test drive after some minor adjustments to the Bowden cable and modulator - what a fun thing it is!!!
[video=youtube_share;A9UZeUYJOzw]https://youtu.be/A9UZeUYJOzw[/video]
Regards,
D
Oh yeah, it is stressssssin!!! Prior owner was a local doctor, well into his retirement, this car is not use to it!!! BTW, I see your siggie, 18.9... Wonder what's the average I was getting today, before the snow started???Wow! Is it me? Or does the MPG gauge actually start to bend once it 'pegs' out slightly beyond 10?![]()
Hello Guest !
We wanted to let you know about a new resource that is now available to all 500Eboard members. This is a comprehensive database of all US-market (and soon to include Canadian-market) 500E and E500 models delivered for the 1992 through 1994 model years.
Data for this resource has been compiled continuously since mid-2003, and much of this information is seeing the light of day for the very first time ever. This new resource will allow you to utilize 500Eboard research and resources to track specific cars, their sale history, documented modifications, and other information that has surfaced over the years.
We are also providing analytics about the cars' production. This means that if you are curious as to how many "Signal Red" cars were produced for the US market with a black interior, specifically in Model Year 1993, you can now easily find this information. You can also find aggregated information -- for example, how many "Black Pearl" cars were imported into the US over the three-year span.
You can always find and enjoy this resource by clicking here (bookmark the site for easy reference!), or by going to the “500Eboard Registry and VIN Database” sub-forum below. You can also find a VIN Database button at the top of your screen, for easy access.
We hope you enjoy this resource. A LOT of blood, sweat and tears over nearly 23 years have gone into its creation.
