transmission fluid was on low. was tiny sound coming from the engine, than it became louder and when i finally identified what is this timing chain broke while cruising around 25mph. some intake valves bent, their lifters finished as well. didn't open to see what's going on with pistons, the engine cranks without chain. front timing chain covers small piece is gone, but the cover looks ok to be used again. no fault codes, only one which is airbag is off.
found that Mercedes tranny friction plates are 1.8mm thick and the one i got 2mm. hope it fits.
Can i use intake cams again or need to buy new?
