B
Brianarb
Guest
Hi,
Long-time Mercedes owner but new to this forum. Don't know if anyone has encountered this issue before with their vehicle. My car is a '94 e420 with 102k on odometer. Seems that the default answer is often a new transmission. However, recently, when it is cold outside (i.e., 30 or so degrees), the car will have a slight slip into 4th gear. Once the car is warm, the vehicle will shift fine without a slip into 4th gear. Fluid looks clear and red. Seems that the shift quality of the vehicle sometimes differs as well. It will sometimes shift soft and sometimes the shifts are firm. Odd thing is that when the temperatures are above freezing, the problem does not appear.
Thinking of less expensive things to test first, I am planning on a fluid and filter change but wonder if the vacuum modulator could be acting up. I am in Delaware and have not found many decent mechanics in this area who know how to really diagnose these types of cars.
I am used to readily seeing the vacuum lines for the modulator based upon having owned Mercedes diesels in the past but am not familiar with the layout of this model. Any thoughts?
Thanks,
Brian
Thanks,
Brian
