Thanks guys. So the one can (1.5 oz) is all that's required and then the rest would be regular R134a?
Correct.
Just got an email from the regional sales manager from ClipLight and he informed me that they've been out of the 946KIT which I've used in the past, so it hasn't been available on Amazon. He said it should be back next week.
In a nutshell, here's how it works:
You evacuate the system and pull a vacuum. If the system leaks down to less than 25" of Hg in five minutes or less, you can't use the product. If it doesn't leak down based on the prior requirements, you can use it and it should contain the leak.
If the system has been opened or leaked down for more than a few hours, I replace the receiver/dryer.
Pull a vacuum for several hours to boil out any moisture.
There is a process by which the kit instructions have you evacuate the filler line and fitting - it's outlined in the instructions. Once this is done with a vacuum on the system, you empty the can of sealer into the system, then charge it with refrigerant. You need to run the system for 20-30 minutes after charging to circulate the sealer.
I'm not keen about sealers, additives, etc., however, this stuff has extended the life of several marginal AC systems that were going to need major (evaporator) repairs. This was in W140 and W124 systems that are known to develop leaks related to dissimilar metals used in evaporator fittings. One of them lasted for over two years after sealing, the other one over a year after which the car was sold, so it could potentially still be sealed. Also, this was in Florida, so the systems were being used the majority of the time the cars were in use.
Just an observation relative to system leaks/leaking down over time:
The hoses used in these systems, if original, will allow leakage at the molecular level over time. If possible, replacing hoses with barrier style material will eliminate this issue. If you're topping off your AC annually and it's otherwise functional, this is probably why. Any industrial hose supplier can rebuild your existing hoses with barrier type material for a reasonable amount.
Dan
