I have this problem only on very hot days, over 95, while driving in traffic or after parked for awhile. The AC will be working fine then suddenly extremely hot air comes out of the side vents while the center vents continue to blow cold air. I found that by switching the control to the next AC button and putting the fan on high, after a few minutes I can hear and feel the air flow change and then I switch to the regular AC button and everything is fine. Could it be that by increasing the airflow through the evaporator thus causing a pressure change in the system and then it returns to normal operation? It has only happened on very hot days. Also if the fan happens to be on the low setting it will happen more often. Aux fans are working. Maybe viscous fan clutch problem, but the engine temperature doesn't rise.
