Alternator question
Vincentjr
Active member
So as you guys have known I have an 89 300 TE with an M103 and also my parts car is a 95 E320 with an M104 while doing random research on the M103 alternator I had seen pictures of what looked like the alternator that I pulled out of my M104 if I switch the wiring to the fuse block will that alternator match up if I have to swap pulleys whatever as long as it bolts in thank you all for input and direction
