Back glass molding removal help needed
Ertech
Hi guys I did some research but couldn’t find the answer how do you remove the molding around the back glass got water coming in between the glass and the side
thanks again guys
erick
With my luck I broke the glass
let the fun begin
thanks
Erick
Erick:
I have broken the glass on all 3 500E500E's i have parted as well as the one car I sent to paint. It is very easy to do...I feel your pain.
Jeff
Anyone have tips on how to NOT break the rear glass when removing...?
The trick was to seal the glass from the inside in case of leak
is the 036 glass dealer only?
036 glass is dealer only, and you'll probably have to buy local... many internet dealers won't ship glass.
:tumble:
A friend of mine who painted himself his 199 .036 last year told me it is difficult to remove the rear glass moulding.
First you tap slowly with two small rubber hammers one side out of the inner gap in the outward direction.
Later tap slowy from under the moulding hitting in the up direction so the moulding can get out of the grove.
That’s how he explained if I remember correctly.
I was joking with him last year about how ‘brave’ he was about removing the rear glass.
Maybe there is a specific or special tool from MB???
Btw, he is a car restoration guy, mechanic and painter which he went to a full time specific car auto mechanic school called Harry Fultz.
Sent from my iPhone using Tapatalk Pro
now the main question
on a new glass does the molding go on the glass before installing the glass?
thanks
thanks
My friend mentioned that yes, the moulding must be placed on the glass before the glass is mounted back.
It is fairly difficult to remove the trim and put back with glass in.
1. Never press against the glass with metal tools, like thin screw drivers, etc. At first, you might be having some success, but you will walk a fine line, then suddenly you will see a fine line on the windshield.
2. I think gaps between the trim and the car body are too tight to remove the trim without bending or damaging it.
3. 9 times out of 10, the trim probably needs to be carefully sacrificed in order to remove the glass without breaking the glass.
I have successfully removed back glass out of 300ce's, and it's also a pain with tight tolerances and all. The clean removal success is probably similar to removing the 500e back glass. It is not my favorite MB back glass engineering.....
in that case it should be almost imposible
If new trims are still available, or if you can get good ones from a junkyard, you could always Dremel off the old trims... maybe?
:sawzall:
I was able to save the moldings
what color are the moldings?
mine is like a lite bronze
are the faded from another color?
thanks
The glass and roof trims are anodized a gloss black when new and tend to fade to a bronze color over time.
drew
