Keep your eye on these.
http://www.jlaudio.com/10tw3-d4-car-audio-tw3-subwoofer-drivers-92184
If you do the math (and I hope you do, because it'll check mine), I think you can custom mold a fiberglass enclosure that's 17"x11"x7"; 1309 cubic inches, or .76 cubic feet. 7" is a tad tall, but no taller than the head rests when down. When you look at the spec sheet on the JLAudio website, the number that's in question is the 11" (because it's a 10" sub, and I'm not sure how much space you need from the inside enclosure wall, if any). But .76 cubic feet is plenty, and if you reduce it to 6" tall, it's still plenty. Fiberglass isn't as thick as the box material.
I've been waiting and hoping they did an 8" of the same design, as that would fit EASILY. And judging by the way my 10" knocks from the trunk pocket, with it in the cabin, it wouldn't need to knock as hard. I'd use the same amp anyway from the same location, so all the installer would have to do would be get the wire inside the cabin.
When I discussed this with them before, the JLAudio subs weren't out yet, and they were on the fence about whether the enclosure would be big enough for a "regular" 10". The one I have in the trunk was their best at the time for a small enclosure (.75 cubic feet minimum). Not wanting a disappointed customer, they got risk averse on me and advised against it. They also didn't think an 8" would give enough punch. I'm thinking about revisiting that conversation with this JLAudio sub.
