Hi all, not sure if this belongs here or in the M119 engine category, but I've been trying to locate the source of a pretty major coolant leak on my '94 E500 for several weeks now. After taking GSXR's excellent advice and finally investing in a cooling system pressure tester, I think I've found the culprit: The large hose at the top driver's side of the engine that runs from the back end of the engine, through the inner fire wall, curves around between the blower motor box and the brake booster, and finally attaches to a metal pipe closer to the main fire wall. Pictures attached, including two that show exactly where the hose is leaking, which appears to be almost exactly where it passes through the inner fire wall.
What is this hose? Is it still available to purchase and, if so, what's the correct part number? Lastly, how difficult is it to replace? Looks easy enough to detach from the metal pipe on the fire wall side, but it's so tight on the engine side that I can't even really see where it attaches on that end. Any advice? TIA!
EDIT: So I just found Gerry's post about replacing this hose as part of his Homeric top-end refresh odyssey, so I think I know that (a) this thing is a heater hose, (b) p/n 124-830-76-96, and (c) it looks like one hell of a party to replace, especially if you don't already have the intake manifold off the car.
RESTO PROJECT: M119 / W124 / E500 Engine Top-End Refresh | Member Roadtrips and Project Journals
See my previous post — I added some photos at the end. It looks to me like the seal is nearly flush with the timing cover. No question it is original. I will do the latter like you did, but will also gauge with the seal tool.
www.500eboard.co
