Hi folks. Wisdom please.
My euro-spec E500 - build date approx. 09/1993 was running fine a few days ago - now refuses to start. It MAY have run out of fuel or the battery may have been low on charge. The battery has been on & off a few times over the past 3 months while it was at the body shop being fettled. Every time the battery was reconnected, it started & ran fine without problem.
It now has about 3 - 4 imperial gallons of fresh 98 octane fuel on board. Cranks fine, all the dash lights up as you would normally expect. No clicking from the fuel relay but equally - no noise from the fuel pumps and no fuel being delivered to the engine bay. New Bosch fuel pumps were fitted approx. 12 months ago so i doubt they will have failed. yet.
Could this be an immobiliser issue (if it has one?). What is the most likely cause? Failed relay? Fuse? LH module? Something else?
At the moment I have an expensive but really beautiful paperweight stuck at the body shop! I've waited 2 years to get to the point where I can drive him home but that day has not yet come
