Hi All,
I went to start my 1992 500e this morning and was unable to start the motor. I turned the key in the ignition, the panel lights lit as usual but when I turned the key there was one click and nothing. The panel lights went out so I checked the battery which checked out as "good" according to my battery tester. It's a 2 year old AGM with a 5-year guaranteed life so I was puzzled. Not being a Luddite, I of course went to Chat GPT and presented my symptoms and got several paragraphs of suggestions. One of which was to run my jumper cable from the negative terminal to the motor lift bracket which I did. I twisted the key in the ignition switch and presto the motor turned over and started right up.
According to the ChatGPT, the problem is a bad chassis to engine ground strap which it reports is a common problem with W124 and the 500e in particular. My question for you all, the real experts, is where is the engine to chassis ground strap located and is the diagnosis correct?
Many thanks,
Joe
Many thanks,
Joe
