engine fan always on high ....even engine off key on
Ertech
hi guys .
high fan always on oven engine off key on . I know A/c red switch has nothing to do with it but I disconnected it and I also disconnected the 2 blues temp switches , climate control also off . what to do next ?
it might be related to this ongoing problem
thanks
My car has the brown relay. I have a spare green one. I tried replacing it, and the fan is still on.
It's the 2-pin sensor on the intake manifold which provides the signal for the aux fan high speed, and IIRC it's the HVAC pushbutton that actually controls it.
2-pin sensor --> HVAC pushbutton unit --> Relay --> Fans
Check to see if your 2-pin sensor is in spec, and if the harness is good, with a tight connection.
The relay isn't the problem, if it failed, the fans would never turn on. Something upstream is triggering the relay.
if I disconnect the 2 pin sensor should the fans stop?
something has always been weird with Hvac , when I stop on the HVAC the fans cycle on off on off for like 5 sec , now when I play with the buttons on off a few times they stop .
I posted a while ago about this problem.
can I repair the HVAC?
thanks
Disconnecting the 2-pin sensor on the manifold should cause the fans to activate in high-speed mode. If you’re getting the fans to turn off and on with the push buttons I would consider finding a used unit for troubleshooting.
a little update .
1- replace hvac control with a good used one
2- removed the connector to the 2 pin sensor and shorted them
3- disconnected a/c red switch , then shorted them
fan still on high even with engine off key on .
kinda lost lol
2-pin sensor is not a switch, is a resistive type sensor that varies resistance signal to tell the HVAC system what the coolant temp is. Shorting the sockets will tell the system that coolant temp is high, but zero ohms is out of range of the sensor and I don't know what the system does with that "wrong" signal. Usually with the fans off and engine running, if you just unplug the connector from the sensor, the fans turn on high.
A/C red switch, when shorted, will turn the fans on LOW speed. But if the fans are already on high speed, this will do nothing.
You could have something wrong with the wiring causing the relay to be triggered when the HVAC system is not calling for it.
I didn’t see this information on your profile, but what year is your vehicle? The later (face-lifted?) cars have two fan ice-cube relays in the relay box—one for low-speed and one for high-speed.
The plot thickens this morning it’s about 20°C and my sensor checked out at 6.4 k ohms
With the engine off key on, I played with the controls of the Hvac a few times until the fan stopped. Then I went straight to the engine disconnected. The temperature sensor and the fans did not come on. Should I buy a used Hvac in case my second one was not good.? i’m reading conflicting opinions. Does my car have two
relays can one be stuck?
can I be confusing low and high speed?
I was able to make them stop while playing with the ignition . I disconnected the temp sensor and the fans do not kick in . ,I bridges the red sensor and the fans work .
sorry for being confusion
Bridging the red sensor will turn the fans on low speed. This is fairly quiet.
High speed fans are LOUD. There is a big difference between low and high speed.
If you cannot tell a difference, check if someone bypassed the auxiliary fan resistor located behind the driver headlight, below the ASR unit.
ok guys a little update . first off problem is intermittent .
this is what I did so far.
1-replaced the 2 sensors on ac dryer
2-replaced blue sensor for high speed fan
3-replaced hvac control with a spare one I have <2 nd might still be bad??>.
4-upper and lower harness were replaces a few years ago
Fans still on high as soon as I turn the car on.
don't know where to go from here .
thanks for guidance .
Erick
I'm at a loss at this point. You've replaced all the components in the system. You could try swapping a different relay for grins but that's a long shot.
Full schematics are at this link, they cross sideways between pages 3 and 4, best to print them out and tape the pages together.
