Another engine oil question... Mobil1 ESP Formula 5W-30 (Long Life) with intervals of 30K km was put in my engine. Is this a safe oil for the E500E?
Is Mobil1 ESP Formula 5W-30 (Long Life) safe to use?
http://www.mobiloil.com/USA-English/MotorOil/Oils/Mobil_1_ESP_Formula_5W-30.aspx
If it is a Group IV/V oil, then yes it would be good stuff to use. I personally do not like oils with a very wide viscosity spread like 5W-50 as this is often achieved via VII's (Viscosity Index Improvers), which are not desirable. I would still prefer Red Line as my top choice as they have good products and honest marketing/advertising. Amsoil has some very good products (not all) but their pyramid-style sales scheme is annoying. Even if Mobil had a fantastic product, I still would prefer not to use Mobil, as their marketing (at least in the USA) became misleading if not downright deceitful, and I don't want to support a company that has (IMO) shady business practices. I'll put my dollars in Red Line's pockets instead.I think Mobil1 5w-50 Rally Formula, which surprisingly you can't get in the U.S, still is the good old engine oil they made before 2003. I can't find exact proof, but professionals over here claim it's still based on the group IV/V stock. It'd be nice to know for sure though. If it really is group IV/V base stock, and unchanged since before 2003, would you still prefer Red Line and Amsoil before M-1 Rally Formula Dave?
I'm happy to see M1 TDT 5W-40 back on the shelves locally & am stocking up for the future since its availability seems subject to change.No issues... that should be very good stuff. Only caveat is mentioned on Red Line's website:I'm about to do an oil change - looking to use Redline 15w50, since I already have some... any issues with this oil for an M119?
"Not recommended for use in cold climates (-20C/-4°F for 15W50)"
Unless you live in Canada, Minnesota, North Dakota, etc it's not likely you'll see temps that low.
More info on the ENEOS oil is in this thread.I love ENEOS 0W‑50 in my M119. Switch over from Mobile1 15W50 22k miles ago. So far so good.
why the oil level should be halfway between the max and min ?The official word from MB:
http://www.w124performance.com/docs/mb/other/oil_level_checking.pdf
"Ideally, the engine oil level should be around halfway between the MAX and MIN marks on the oil dipstick."
Because that is how Mercedes engineered the dipstick. It is not "full" and "add", which mean something very different.why the oil level should be halfway between the max and min ?
I've running Motul 300V Power 5w-40 with great results, one the best synthetic oils you can get, if not the best oil. I do track my car and drive in hot weather, the oil is working perfectly.Any particular synthetic I should try?
And worth every penny...although my cost is bellow that price per quart.Motul 300V is great stuff, but it is on the higher end of the price scale, roughly $15/qt.
today i change the engine oil filter with oil,i add 8 liter ,the dipstick is in between the max and min?is it sure normal?The official word from MB:
I decided to go a bit heavier, with a RedLine 15W-50 synthetic oil, rather than 10W-40, because of the warmer climate that i live in here in Texas. If I was still back up north, I'd definitely be going 10W-40. I have been using 20W-50 in most of my cars (even up north) for many years with no problems, and 15W-40 diesel oil in my wife's wagon again with no problems here in Texas.Yes, USA oils are generally not the same as European oils, for various reasons.
That said, MB specifies an xW-40 or xW-50 oil for the M119 when operated in warm climates. Either a 5W-40 or 10W-40 is fine, that is what I use in all my M119's. The 10W-30 is acceptable in cold climates but I personally wouldn't use it at all, there's no need if you have fully synthetic oil, as the 10W-40 will pour just as easily in sub-freezing temps as 10W-30, so there's nothing to be gained by using the thinner stuff.
How often do you change it ? I'd expect the opposite... usually, lots of freeway miles should be easier on the oil than lots of short trips (even if your 3kmi was high RPM, high temp). No matter though, the analysis was still fine, and it's a good thing you didn't have lesser oil in there! It's also impressive that your engine apparently used no more than 1 quart of oil, if that much, in 11kmi. If you were a quart low (at the Min mark) relative to your initial ~70% level, the low level light would have been turning on intermittently.I checked the disptick a week after changing oil on a warm engine (at both of the recent oil changes), and it was past the middle, probably just under 3/4 way to max. While I did not check the oil level before my change this time, it was done about two months ago and level was just over the middle. I have no idea why the TBN would be lower. I am going to guess that my summer roadtrips had something to do with this: I put nearly 3k miles on my car in about a week, all of it at high speeds, very hot ambient temps, with engine temp hovering around 100C for several hours at a time. Eitherway, I do plan on changing the oil in December. The last oil change was even greater mileage (11k) but TBN was 2.
Since Motul is not a cheap oil, the cost you listed for an oil change (with Motul) is not that bad. Some things are worth the price of admission and when it comes to protecting my car with the best, the price (for me anyway) is irrelevant. I change my oil every 6-7K miles. Since I haven't ran my car hard at the track, or for many laps over and over, my oil changes have not been sooner than 6-7K miles - but in the future, if I decide to run harder and longer at the track, the oil changes would be right after the track events.I m start thinking to switch to Motul , but boy $160 for every oil change + $20 filterHow often do you change it ?
So my next oil change will be the Motul 300V but it is not go n buy product. I ll have to find a decent retailer here in MN.Since Motul is not a cheap oil, the cost you listed for an oil change (with Motul) is not that bad.
If you are not planing to track your car at all, then maybe the 300V Power oil that I use might not be needed in your case, although having good perfection at higher temperatures is always a good thing and the M119 engines do like to run hot.
Maybe you can find a Motul dealer from here - http://www.motul.com/us/en-us/resellers?utf8=✓&activities[1]=1&q=Minisota&commit=Search or one close enough to save on shipping, or drive to. Otherwise, you might have to buy it online. Have you tried searching the web for Motul dealers/resellers in your area?So my next oil change will be the Motul 300V but it is not go n buy product. I ll have to find a decent retailer here in MN.![]()
5-7K and hard driving is no problem. Motul.usa told me that I can change the oil at whatever intervals I was changing my previous synthetic oil and when hard street use was brought up (and light track days) I was told that anything up to 10k would be no problem. Under normal driving conditions, 12K is no problem as well and that millage was also mentioned by an independent oil analysis group, Blackstone Laboratories.Do you think I can run Motul for about 5-7K with no track but occasional fast driving on a highways ? For some reason my 500E pretty much does not consume any oil may be 100gramm per 3000miles if so but oil becomes dark brown in couple of thousand miles which annoys me ?
Oil turning dark is not always a bad thing, the oil is cleaning your engine. With Motul, the color is not as dark after the same milage used as was with Mobil 1 0w-40 oil I ran previously. I compared my second Motul oil change (after 6K) and how I remembered the last oil change with Mobile after 6K and Mobile looked a lot darker. I was running Mobile 1 for five years before I switched to Motul three years ago. On a side note, the most I drive in one year is 6-6.5K miles, so my cost for changing my oil once a year is not that much, with even the higher price Motul commands.
As far as the oil grade, that's up to you, based own your weather conditions. I prefer a lighter weight oil, for less friction at startup and although I live in a warm climate, I like having more protection from wear on an cold engine, so for me the 5w-40 grade is perfect. The extra protection the racing oil provides for just street use is the main reason I decided to switch to Motul, although their non racing oils are also excellent, I just need one oil that can be used for both street and light track days.
So basically:
1. You can go out and do your periodic run over 140mph at will and feel at ease with what's going on inside your engine.
2. The 300V oil is overkill for street use...but overkill is underrated and never hurts to have.
As it should be. Lubrication aside, oil picks up and traps some of the residue left inside the block which plays into the darker color.I do not know what Mobil 1 was cleaning in my engine , but my engine looks shiny inside , pure iron no yellowish residue or whatsoever , shiny like a new dollar coin .
These cars need to be driven. Do you know if the previous owner drove the car offten? I have noticed that my car feels better now as well, comparred to when I first got it. Prior to my purchase, the original owner told me that he mostly used the car to drive his wife and granddaughter on the weekends, or a coupe of hundred miles on the freeway once a month.It seems that my 500E lives/feels now better than before even though the first owner was VP of MB NA and second a truly Porsche fan .
As far as pricing goes, I might not be the best person to ask. I get my oil from my tuner at a discount price and I pay in cash. My cost is $20 for a 2 liter metal can and I've seen the same can go from $29 to $40 online. I think the 2 liter cans are sold more so than the 1 liter plastic bottles, but I bet for motorcycles, the 1 liter bottle is easier to use. Btw, I tried a few motorcycle shops in L.A. who carry Motul and they only sell the 1 liter bottles and only a few grades of oil are stocked, 5w-40 was not one of them.What is considered to be a good price for Motul ? What size of bottle or cans should I by ? 1 qrt ? 2 qrt or any larger ? Cuz usually larger cans are much cheaper .
