Fuel Relay
@dbb7697 - Correct, it will be under the passenger rear seat.
Back again. I cannot see the relay with fuse under the rear seat. Here is what I am seeing. Can it be located anywhere else? The black box under the foam I moved and nothing under that either. Thanks in advance.
I believe it's the blue cube relay in your photos. The relay in your car may not have the fuse, which is odd, but maybe some were built that way.
Thank you. That is what I was thinking. Only fuse down there. Here are some pics of all sides of the relay.
Just tested and works in the test. Next is the fuel pump. Is there a special tool to take the shield off that covers the fuel pump?
Pump info at link below. Replace both if the are old/original. I got mine from Amazon for quick delivery:
If the high pressure hose exiting the filter is not recent OE... consider that too, it's a fire hazard & frequent leaker.
You can jump the terminals at the relay and see if the pumps run or not.
:mushroom:
Dealer only for the high-pressure hose. Read this thread, post #3 through #7:
