HOW-TO: Replace W124 (500E, E500) Front Brake Rotors and Pads
Site Honcho
The replacement of the 500E/E500 front brake rotors is a job that is only done occasionally. The MB specification for rotor thickness is [TBD / varies with rotor size].
The job will take a first-timer around 1-1.5 hours per side; the second side generally goes faster. It is HIGHLY recommended to replace the brake pads and brake pad wear sensors at the same time the rotors are replaced. The job is around a 3 in difficulty on a 1-10 scale.
Tools Required:
  • 19mm socket (6-point preferred), 1/2" drive
  • 1/2" drive ratchet
  • Channel-lock or other slip-jaw pliers
  • Hammer
  • Punch
  • Needle-nose pliers
  • Bungee cord or coat hanger
  • 5mm Allen socket or Allen key
  • Dial gauge and dial gauge holder
  • Lug wrench
  • Brake cleaner
  • Rags
  • Blue thread-locker
  • Floor jack
  • Brake paste
Parts Required:
  • Brake rotors (pair; appropriate for your car)
    • 129 421 20 12 64 (both sides, for cars with VIN B930494 and lower)
    • 129 421 17 12 64 (front left, for cars with VIN B930495 and higher)
    • 129 421 18 12 64 (front right, for cars with VIN B930495 and higher)
  • Front brake pads 005 420 02 20 41 (set of four; appropriate for your car)
  • Brake pad wear sensors 140 540 12 17 (four needed)
Before lifting your car's wheel off the ground, barely loosen all five of the lug bolts. You can use your lug wrench, or (as shown here) you can use an air-powered or battery-powered impact wrench.
After breaking loose the lug bolts, carefully jack up the car in front, so that the front wheel is a couple of inches off the ground.
Finishing loosening and removing the five lug bolts, and remove the wheel from the car. Upon doing this, you will see this view of the disc and brake assembly.
I decided to clean my lug bolts using a wire wheel, to remove rust and surface corrosion from the bolts. You can see the process of doing this in the photos below. Of course, this is optional, but it helps neaten things up.
The next step is to remove the caliper. It is held onto the car by two 19mm bolts, which are accessed from behind the wheel. I used a 1/2" drive socket with a six-point short socket. It may take some effort to break these bolts free. A few blows with a hammer on the end of the ratchet can help break them loose. Make sure your socket has a GOOD purchase on the head of the bolt.
Upon removing the bolts, you will see that they have Blue Loctite on the ends of them. I used my wire wheel to remove this old Blue Loctite.
Another view, removing the second (uppermost) of the two bolts that hold the caliper to the car.
Then, unplug the two brake pad wear sensors from the electrical connector behind the caliper.
Using your punch and a hammer, hammer the ends of the two brake pad retaining pins inward, driving them out of the calipers. Once they are mostly released, use your needle-nose pliers to remove them from the calipers from the rear side, as shown in the second photo.
After removing the retaining pins, the brake pad retaining spring will be loosened. Remove it from the car, and set it and the pins aside for cleaning.
Using your channel-lock pliers, carefully and slowly squeeze the tabs of each brake pad toward the outside of the caliper. This compresses the pistons and allows the removal of the brake pad, as shown in the second photo below. Repeat for the other brake pad.
From there, you can lift the caliper off of the brake rotor. Using your bungee cord, or a piece of coat hanger wire, suspend the caliper from the inside of the wheel well, so that you are not stretching or stressing the brake line.
Here is what the bare brake rotors looks like, after caliper removal.
Find the 5mm Allen screw that holds the rotor to the hub. Using your Allen socket or Allen key, remove the screw from the rotor. It should not be very tight. Note that it also has Blue Loctite on its end, as show in the third photo below.
With the retaining screw removed, the rotor should loosen and slide right off of the hub, as shown in the two photos below. There is a chance, if the car has been driven on salty roads in the winter, that the rotor hat is rusted to the inside of the hub. If the rotor doesn't come off of the hub easily, you can bang it from behind with your hammer (while rotating it) to loosen it and coax it to come off of the hub.
Here is what the hub looks like, with the rotor removed. Note the two metal guide pins embedded into the hub. These press into the rotor and hold it into place.
Here are a couple of views of the brake pad. Notice that there was plenty of wear left on it. The second photo shows it was a Jurid brand pad.
Using a wire brush (brass or steel), brush off the surface of the hub, where it contacts the metal of the rotor hat.
After you brush the hub surface, coat it with a light, thin layer of anti-seize paste. This will make it much easier to remove the rotor the next time it needs to be replaced.
Next, it is time to install the new rotor. On my car, the front rotors are different part numbers on the left and right sides, hence I have marked the part boxes "driver" and "passenger" side. Early 500Es up to about mid/late-1993 I believe use the the same part number for both rotors. You will need to ascertain what rotors your car requires. The "directional" rotors are for the facelift cars with the larger 320mm front brakes from the SL600.
A comparison of the old (top) and new (bottom) rotors. Note that like the factory rotors, the ATE branded rotors I used are also painted gray. This gray coating wears off after just a few applications of the brakes.
The ATE rotors also have the wear spec etched onto the hats, in two different places.
Install the new rotor onto the hub, lining up the appropriate alignment pins and the hole for the retaining screw.
Here is my cleaned up hardware, ready for the installation. You can see where I added Blue Loctite to the ends of the retaining screw and the caliper bolts.
Place the caliper onto the rotor in proper position, and insert and tighten the 5mm Allen retaining screw. The torque spec for this 5mm Allen retaining screw is 10Nm. Then, install and tighten the bolts into the rear of the caliper that hold it to the car. The torque spec for these two 19mm brake caliper bolts is 115 Nm (quite tight).
Carefully press the pistons back into the calipers, one side at a time. This will make room for the new brake pads to be installed. Before you install the pads, make sure you smear the rear of each pad with a layer of silver MB brake paste. Also coat the edges of the metal pad backing plates with brake paste, where they contact the insides of the calipers. This will help prevent squeaking.
Re-insert the pins and the brake pad retaining spring from the rear side, and pound them back into place.
Once the pads are in place, install the two new brake pad wear sensors. It is advisable not to re-use the old sensors, though it is possible to do this in a "pinch." This is a cheap part, so advisable to purchase them in advance.
Once the caliper is installed, and the brake pads are installed, it is HIGHLY ADVISABLE to check the rotor for runout. I used my dial gauge to measure this. The MB factory spec is 0.12mm runout. My measurement with the new rotor was 0.025mm runout on both the rotor braking surface and the rotor hat, which was well below the MB factory spec (as it should be for a new rotor).
The last thing I did, which I did during the entire job, was to clean the removed wheel with water and Griot's Garage Heavy-Duty Wheel Cleaner. I did three applications to the front and back of the wheel. Though it didn't clean up 100%, particularly on the rear, it certainly looks MUCH better than it did before. This is the front of the wheel. It is going to need refinishing again in the future, as I am JUST starting to see the paint beginning to peel.
From there, I just re-installed the wheel onto the car, and tightened down the lug bolts. Job complete.
I hope this HOW-TO is helpful for those replacing their front pads and rotors.
As an FYI, for my car. After removing the rotor, I measured its thickness. It was 27.8mm. This is below the 28mm "wear limit" specification from Mercedes, and well below the 28.5mm specified "limit dimension for maintenance service" that is in the MB specs.
So, to conclude -- my rotors were definitely out of thickness spec and in need of replacement.
Again, as mentioned in this thread, a good rule of thumb is that if you can feel a lip that snags your fingernail at the lip of a rotor, it's likely at spec or requiring replacement. At minimum, a lip you can clearly feel warrants a measurement and then a determination as to whether to replace it or not.
I measured the rotor I removed from the passenger side, and it came out to 27.5mm. So, it was slightly thinner than the driver's side. The Jurid brake pads like on the driver's side had plenty of wear left on them. My records show that the front pads had last been replaced in 2005, when I lived in Portland, OR. They lasted quite a few miles.
The Akebono pads I used were the EURO 561 pads, for the front. They can be used with the larger 320mm or pre-facelift 300mm front rotors.
I actually grease the retaining screws now - certainly not lock tight them. They have little function when the wheel is on and lug bolts torqued. They are just there to stop the brake rotor wobbling around if the wheel is removed.
What can happen is they seize in there or the lock tight gets a purchase and the Allen head strips out. Hence why I always renew them, remove any pre applied lock tight first, grease and nip up. Never an issue after that.
Some are so tight I have to weld nuts on to get them out. Mechanics seem to love over tightening them as if its function is of importance.
Just a tip from the land of rain and rust
Interesting. Both my retaining screws came right out, no corrosion. I cleaned them off with some grease remover and a wire brush, and they cleaned right up. Applied more Loctite (not much needed) and all good. I didn't find any corrosion or problems relating to these screws on my car. May be more of an issue if the car is driven on salted winter roads.
I usually heat them good and proper before attempting removal. This helps soften any lock tight that is in there. I'd say 60/70 % of them come out and the rest put up a fight. I buy bags of the little screws and change them every time.
In case anyone is interested, the Akebono Euro pads for the rear of the E500E are EURO 495.
[GSXR edit: The #495 rear pads fit 278x24 rear brakes, used on all USA/Japan spec cars, and Euro/ROW through roughly March 1993 production. Late-build Euro/ROW cars will use #603 rear pads, as will any cars with the "Silver Arrow" brake upgrade package.]
Gerry, Nice write-up here. I'd like to make one comment. Like you I've used MB brake paste on several brake jobs on my E320. No squeaks or screeching--good stuff. I re-read the FSM prior to doing a front brake job recently and realized if using factory pads which have the dimpled circular pattern on the backing plate (like the pad in your photo) you install the pads dry. 42-0160 part B makes 2 references to this fact.
I believe its the same for your car which like mine uses the ATE iron 4 piston front calipers. I did this and no noise at all. Prior to installation I wire brushed the caliper ledges where the pads sit so they were clean.
Not sure if any of the after market pads have the same circular dots.
Regards,
Peter Weissman
Some pad brands and models have the dots (and include blacking plates) and some don't.
The Akebonos I installed came with metal backing plates, and I added brake paste to them. I will always err (personally) on the side of using brake paste rather than not.
The Jurid pads that I removed had the circular dot pattern and also metal backing plates.
And a good catch, about cleaning the caliper ledges where the pads rest. I did this but didn't show it in the HOW-TO. It is a really good idea to do this, and it in many cases will help cut down on noise.
Photo 16 has the caliper being hung from a bungee cord and hooked over a hydraulic line. I would try to hang the caliper from the front spring if possible. thx for the great write-up very helpful.
