Recently acquired another 95 sl500 with low miles and good records.
Shortly after purchase, it developed a miss shortly after startup after sitting for a week....and after driving and getting up to temp, idle in gear gets bad. Really felt like a typical cap issue with moisture buildup.
After driving for a bit, the engine runs great. Even when it was idling poorly, acceleration was fine.
No fault codes found.
Plugs were iridiums.switched to f8dc4 and gapped.
Ruled out caps, rotors, rear cap covers, and leads.
Upper harness is updated but throttle body is original but shows no issue.
Maf was rebuilt but have ruled that out.
Took out EGR and appears to be moving freely.
If I drive it for a day, park overnight and drive it the next, car doesn't repeat issues. Only seems to be if it sits for multiple days. I will also drive to a destination while it's missing at idle, park.it for a bit and will then give no.issue for rest of day.
Again, it feels like a typical cap moisture symptom or a stuck EGR sucking in unmetered air.
Has anyone experienced this?
I have also noticed the rpm at idle sometimes will sit at 500 rpm and not increase after shifting to p/n. Again, no code...assuming it's a safety switch intermittent issue. It'll do this with a smoothed out idle as well.
Assuming it's not correlated.
Thanks!
Thanks!
