I also purchased a parts car to go with this.The parts car is a 94 with ASR.
On the running car, I have a slow/late pedal response.The car runs like it's on 4 cylinders.I have had the car for about 3 weeks and I have done some research.The pedal travel is half way before it moves forward and after 30mph, it is fine.I did a fuel pressure test and I am getting 55 on idle and 68 on rev.There is no miss when idling.When I put the car in gear, the rpms drop to around 400 and almost tries to die.From idle to rev, the response is also late/lagging.I went ahead and changed the Egas modulator, cleaned the MASS sensor , EZL(ignition control module )and cleaned the intake with acetone.Not sure if this could be tune up related because I am not getting any miss or shake from a car that needs a tune up.
I manually counted the blinks from the diag post and I am getting codes 6,7 and 15.please advice
1 No Faults in System -
2 Heated oxygen sensor inoperative Test LH-SFI unit
3 Lambda control inoperative Test LH-SFI unit
4 Air injection inoperative Test LH-SFI unit
5 Exhaust gas recirculation inoperative Test LH-SFI unit
6 Idle speed control inoperative Test electronic accelerator
7 Ignition system defective Test distributor igntion system
8 Engine coolant temperature sensor, open/short Test LH-SFI unit
9 Intake air temperature sensor, open/short Test LH-SFI unit
10 Voltage at mass air flow sensor too high/low Test LH-SFI unit
11 TN-signal (rpm) at LH-SFI control module (N3/1) defective Test LH-SFI unit
12 Heated oxygen sensor heater, open/short circuit Test LH-SFI unit
13 Camshaft position sensor signal of ignition control module (N1/3) defective Test LH-SFI unit
14 Intake manifold pressure at start in N1/3 too low/high Test LH-SFI unit
15 Wide open throttle information defective Test LH-SFI unit
16 Closed throttle position information defective Test electronic accelerator
17 Data exchange malfunction between individual control modules Test DM Step: 7.0
18 Adjustable camshaft timing solenoid, open/short circuit Test LH-SFI unit
19 Fuel injectors open/short or self-adaptation in LH-SFI control module (N3/1) at limit Test LH-SFI unit and reset adaptation to mean value
20 Speed signal not present Test electronic accelerator
