94 E500, 125K miles.
Intermittent no crank. Very intermittent, probably happens once per 30 starts. Originally thought fuse 5 was faulty because starter engaged after replacing fuse 5. Then a few days later, no crank again. During troubleshooting, problem mysteriously fixed itself, now have about 20 good crank/start cycles. After a search of past posts, I’m aware of the normal culprits, ignition switch, battery, battery connections, NSS, starter wire harness decay, fuse B and C, alarm immobilizer/K38 relay, and the starter itself. Easy items to check have been checked, nothing noteworthy found.
I’m OK to just drive the car until the problem becomes more frequent thereby making diagnosis possible. The problem with this is that I don’t want to be stranded away from home if the problem happens again. On my E320’s it was possible to start the car from under the hood by placing the ignition switch in the run position and then jumpering +12v to the center pin of the three pin connector behind the the brake booster. IIRC, this would bypass the ignition switch, the NSS, and the K38 immobilize function. If you had a good battery, good battery connections and a good starter, it would start and run.
Does this work on the 94 E500? If not is anyone aware of another simple bypass solution to at least prevent a stranding?
Thanks,
J. M. van Swaay
Thanks,
J. M. van Swaay
