Hi guys,
Any feed back on what happened today is appreciated.. I went through the transmission service manuals and trouble shooting manuals but found nothin similar to this issue.. Problem has not re-occured, yet..
As I was waiting on a Red light today, I felt the transmission disengage by itself. As soon as the light turned I pushed the gas, the revvs would pass over 3K but the car moved as if it were being pushed. I was able to go into a large parking area on my side. Slowly I creeped in. I found a spot and stopped the car. I toggled with the shifter, reverse engages, 1st and 2nd also engaged. I was able to get back on the road in 2nd. then I shifted to D and all worked as if nothing had happened..? Are these signs that some more parts are about to go on my huckleberry.. vacuum leak, bad solenoid, clutch,
(Idle is a little higher now that I replaced the MAS. It will be at about 900 rpm when in P, and drops to 500 when the gears engaged.. I don't think this matters though)
Thankz guys..
Thankz guys..
