Hi,
anybody has the real meaning of the 7 positions of the Trim Plug of the Jetronik, is ist the same as the KE code or is ist different.
As I made the manual conversion I want to see if there is a possibility to adapt the LH a little better to the manual tranny.
In Position 1 the idle is a little high, seem that in position 2 and 4 this is better. In Position 4 the pick-up in 4th is not as brilliant ans in position 4 or 7. In position 7 the consumption is higher! The problem is that any time you change the posision you have to make a longer drive to give the ECU do equilibrate.
Any idea how the injection-diagrams differs in the different positions?
Best Pagodino
Best Pagodino
