Hello everyone...I was told by the prior owner of my vehicle that he installed a Quaife LSD. I have confirmed that the differential has been replaced with 2.82 gearing (not sure where it come from though...does the "023" stamped on the drivers side mean anything?). So I'm assuming I actually do have an LSD.
Anyway, while turning (mostly to the left) from a stop, I feel a notchiness from the differential. It is not always notchy, but when it is, you can certainly feel it. I'm wondering if maybe the incorrect gear oil was used by the prior owner? Or is this just how this LSD works (I just read a post from Dave where he described this notchiness and indicated it was normal during initial break-in?)? Should I try swapping out the oil and if so, with what? I recall some posts where there was some debate on which type of gear oil to use but I have not been able to track these down again.
