List of EPC VINs for E60 Limited Cars (Codes 957+958)
Site Honcho
This is courtesy of our member "esodnehoh" in Germany. It comes from official MB data per the EPC.
The total seems to be 45 cars with both option codes originally in the data card. I would expect these to be confirmed by same codes in the VIN cards and stickers under the rear deck.
[TABLE="class: cms_table, width: 142"] [TR] [TD]WDB1240361C131823[/TD] [/TR] [TR] [TD]WDB1240361C132346[/TD] [/TR] [TR] [TD]WDB1240361C133101[/TD] [/TR] [TR] [TD]WDB1240361C133844[/TD] [/TR] [TR] [TD]WDB1240361C136478[/TD] [/TR] [TR] [TD]WDB1240361C138116[/TD] [/TR] [TR] [TD]WDB1240361C144263[/TD] [/TR] [TR] [TD]WDB1240361C144815[/TD] [/TR] [TR] [TD]WDB1240361C150601[/TD] [/TR] [TR] [TD]WDB1240361C156658[/TD] [/TR] [TR] [TD]WDB1240361C160356[/TD] [/TR] [TR] [TD]WDB1240361C160617[/TD] [/TR] [TR] [TD]WDB1240361C162390[/TD] [/TR] [TR] [TD]WDB1240361C162674[/TD] [/TR] [TR] [TD]WDB1240361C167396[/TD] [/TR] [TR] [TD]WDB1240361C167589[/TD] [/TR] [TR] [TD]WDB1240361C168392[/TD] [/TR] [TR] [TD]WDB1240361C168952[/TD] [/TR] [TR] [TD]WDB1240361C169787[/TD] [/TR] [TR] [TD]WDB1240361C170333[/TD] [/TR] [TR] [TD]WDB1240361C176354[/TD] [/TR] [TR] [TD]WDB1240361C176359[/TD] [/TR] [TR] [TD]WDB1240361C177228[/TD] [/TR] [TR] [TD]WDB1240361C177598[/TD] [/TR] [TR] [TD]WDB1240361C177608[/TD] [/TR] [TR] [TD]WDB1240361C178567[/TD] [/TR] [TR] [TD]WDB1240361C183327[/TD] [/TR] [TR] [TD]WDB1240361C183482[/TD] [/TR] [TR] [TD]WDB1240361C183488[/TD] [/TR] [TR] [TD]WDB1240361C184306[/TD] [/TR] [TR] [TD]WDB1240361C185952[/TD] [/TR] [TR] [TD]WDB1240361C188669[/TD] [/TR] [TR] [TD]WDB1240361C188909[/TD] [/TR] [TR] [TD]WDB1240361C197661[/TD] [/TR] [TR] [TD]WDB1240361C197810[/TD] [/TR] [TR] [TD]WDB1240361C200075[/TD] [/TR] [TR] [TD]WDB1240361C202094[/TD] [/TR] [TR] [TD]WDB1240361C202605[/TD] [/TR] [TR] [TD]WDB1240361C203149[/TD] [/TR] [TR] [TD]WDB1240361C203598[/TD] [/TR] [TR] [TD]WDB1240361C204258[/TD] [/TR] [TR] [TD]WDB1240361C204818[/TD] [/TR] [TR] [TD]WDB1240361C206302[/TD] [/TR] [TR] [TD]WDB1240361C210227[/TD] [/TR] [TR] [TD]WDB1240361C213356
[/TD] [/TR] [/TABLE]
DataMB has been proven NOT to be as accurate as direct EPC VIN data. There are discrepancies with DataMB, although it is generally pretty good and accurate.
However, the closest thing to the Holy Grail / Bible on MB data is ONLY and ONLY and ONLY the EPC.
I do not own a Mercedes. So i have no access to EPC. Right?
Otherwise, please show me a link to EPC. So i will register and log in.
"a credit card attached to a USA mailing address".
I have family in the US. My brother in St. Joseph, MI. His daughter in Dupont, WA. She is married to a USAF C-17 Globemaster III pilot by the way. I have seen videos and images. Very impressive.
So EPC access will be no problem if i ask them, i suppose. But i won't bother my family. The three VIN decoders i am using now are sufficient for me.
And if i lose my way i will ask you people.:D
You can also get full EPC access as a European. It costs I think perhaps a bit less than the USD 75. I have friends living in Europe who have EPC subscriptions. Anyone in Europe can get it as well.
I crosschecked that the same is written also in EPC.
So for me the the first sentence is indication that SA-codes can be inserted after the car has left the factory. The latter one is showing that evenif Germans are precise there were 'bugs' identification system of MB that can sometimes fail by producing duplicate serial numbers.
Since i only found one VIN - WDB1240361C197810 - that had this "vom Kunden B+B Automobile nachgerüstet'" notification, i must conclude the other 44 VIN are original, so to say. Didn't have any notifications afterwards. Except for the double use of the engine number. But this doesn't affect the 957 and 958, i suppose?
Remains why 29 VIN are noted as E 500. And 16 VIN are noted E 60 AMG. At least, noted in datamb.com.
Is this also in EPC?
Yes, there are a few glitches with the documented engine serial numbers. The system base (VeDoc) where all other systems like EPC/WIS etc withdraw the data from automatically recognizes this. A check info is given for this vehicle to verify the actual engine number of the vehicle if possible. It refers you also to which is the other vin with the same engine serial number recorded. So this can be corrected by the official agent. It has not an influence of code 957.
What was retrofitted by customer B&B?
Yeah somebody put some money in that car. But only on the codes mentioned. Not E60/Limited code. I will verify that later but it's still a original E60 Limited.
If I am not mistaken, corrections cannot be done any more in W124 cars in the MB EPC and (VeDoc).
I contacted MB official dealer a while back and they requested to the documentation dept of MB to correct a typing error in the 'Sales designation ' in one of mine W124 500E's and it was not possible to make corrections in the W124 docs basically that was the answer.
  • Like
Reactions: 036
My 5 cent... Someone just added couple of SA codes to R129. BUT- those adds will be done as just posted above- some comments on EPC, Datacard can´t be changed.
  • Like
Reactions: Eno
Eno, sorry to say but then they told you rubbish. It can be done IF you have the authority to do so. Not many have it. So it can be done in the our cars. Some things certainly can't be done like changing the chassis number, production date, sales point etc. But of course any changes like retrofitting the auxiliary heater for example in the previously mentioned vehicle must be performed with original parts only and by a authorized dealer. Then they add the code and EPC will show then after the quarterly update that the auxiliary heater items for example will be shown with part numbers plus you will see it in the data card as an option (like any other).
Further the so called FO text can be used to add information related to certain items, for example my car. Here is noted and linked to construction group 42, that the brakes are modified by using xyz part numbers and quantity. So while opening group 42 the this Pop up info will come up, however the part number as per the picture is not changed. But the workshop staff can then avoid mishandling
Ah ok, I see. Thnx.
I am not familiar with EPC but the official MB dealer sent an email request to change a "typo" on the sales designation on my 500E and MB replied back cause I saw the email myself, he turned the screen of his computer and I read the email myself.
They confirmed it was a typing mistake of the Sales Designation but could not do nothing.
If I remember correctly it was the responsible dept for documentation that had replied.
Anyways, I know nothing of EPC, never used it, just looked at the screen when ordering parts sometimes.
Yes as said some very essential stuff can not be changed. On the afore said vin 197810, the special equipment has been retrofitted in September 2009. Equipment retrofitted 884,882,819,816,810,581,260,228.
GSXR edit: Added engine / transmission serial numbers. Red text indicates engine serial over ~1000 different sequentially.
External color combo code translations (per column below):
  • 009 = Sapphire Black (exclusive color to E500 Limited models on .036 model)
  • 744 = Brilliant Silver
Interior color combo code translations (per column below):
  • 286 = Black leather w/red insert
  • 287 = Black leather w/green insert
  • 288 = Black leather w/gray insert
VINEPC DataCard typeDataMB typeEngine NumberTransmission NumberNotes / CommentsOriginal Color ComboLink to datacard
1WDB1240361C131823E500E5000091423988861009 / 288Link
2WDB1240361C132346E60 AMGE60 AMG0092063985818009 / 287Link
3WDB1240361C133101E500E5000082403995760744 / 286Link
4WDB1240361C133844E500E5000092553991690009 / 288Link
5WDB1240361C136478E60 AMGE60 AMG0091583995737744 / 288Link
6WDB1240361C138116E500E5000092993995750009 / 288Link
7WDB1240361C144263E500E5000089433999313009 / 288Link
8WDB1240361C144815E500E5000055414003060009 / 288Link
9WDB1240361C150601E500E5000107244012555744 / 288Link
10WDB1240361C156658E60 AMGE60 AMG0093264018229009 / 288Link
11WDB1240361C160356E60 AMGE60 AMGN/A ?!4020209009 / 288Link
12WDB1240361C160617E60 AMGE60 AMG0092974022002009 / 288Link
13WDB1240361C162390E60 AMGE60 AMG0096744019635009 / 288Link
14WDB1240361C162674E500E5000095864023050009 / 288Link
15WDB1240361C167396E500E5000097534029567009 / 288Link
16WDB1240361C167589E60 AMGE60 AMG0093074029640009 / 288Link
17WDB1240361C168392E500E5000095884030736744 / 288Link
18WDB1240361C168952E500E5000097744030682009 / 288Link
19WDB1240361C169787E60 AMGE60 AMG0098144013332009 / 288Link
20WDB1240361C170333E500E5000097644033054009 / 287Link
21WDB1240361C176354E500E5000099144034379009 / 288Link
22WDB1240361C176359E500E5000097954022034744 / 288Link
23WDB1240361C177228E500E5000097574034373009 / 288Link
24WDB1240361C177598E500E5000098674044737For sale 10/2021, click here009 / 288Link
25WDB1240361C177608E60 AMGE60 AMG0096184041625009 / 288Link
26WDB1240361C178567E60 AMGE60 AMG0097984041604009 / 288Link
27WDB1240361C183327E60 AMGE60 AMG0097264051037009 / 288Link
28WDB1240361C183482E500E5000099914049782009 / 288Link
29WDB1240361C183488E500E5000098794049777009 / 288Link
30WDB1240361C184306E60 AMGE60 AMG0099744050895009 / 288Link
31WDB1240361C185952E500E5000100414050919009 / 288Link
32WDB1240361C188669Unknown500E0057034054823no notation in EPC009 / 288Link
33WDB1240361C188909E60 AMGE60 AMG0101264057475009 / 288Link
34WDB1240361C197661E60 AMGE60 AMG0101824062996009 / 288Link
35WDB1240361C197810E60 AMGE60 AMG0102744066896009 / 288Link
36WDB1240361C200075E500E5000103834070768009 / 288Link
37WDB1240361C202094E500E5000103744067845009 / 288Link
38WDB1240361C202605E60 AMGE60 AMG0102884518374744 / 288Link
39WDB1240361C203149E60 AMGE60 AMG0083794066875009 / 288Link
40WDB1240361C203598E500E5000103324067600744 / 288Link
41WDB1240361C204258Unknown500E0102414065918no notation in EPC. Also another amusing notation in FO text notes on EPC data card.009 / 288Link
42WDB1240361C204818E500E5000105284066869009 / 287Link
43
WDB1240361C206302
E500E5000104464062980744 / 288Link
44WDB1240361C210227E500E5000103654084744744 / 288Link
45WDB1240361C213356E500E5000105424090006009 / 288Link
The table above shows all of the 500Es produced that show codes 957 and 958 on the data cards.
All of the cars above, then, would be E500 Limited models, with the addition of AMG 6-liter engine at some point DURING or AFTER production.
Checking each car via the EPC, and via the DataMB site, I have added the notation for each car as it appears in the records. Note that some cars do appear as E60 AMG models, and some appear as E500 models. However, per the data card, ALL of the cars above have six-liter engines.
One other thing to note .... this table above further disproves the "conventional wisdom" about the "12 E60 Limited" models produced, as you can see there were a total of 17 cars that have "E60 AMG" in the data cards, not counting the others which have both codes.
So, even if someone had somehow done a search for "E60 AMG" in the data cards, they would have come up with 17 cars, not 12 cars.
We can put that mythical number to bed, permanently, IMHO.
I added columns to the above table to identify the interior and exterior colors (as shipped from the factory), as well as a link to the EPC data card as displayed by DataMB.com
In my analysis:
  • 41 out of 45 cars had the gray/black leather interior
  • 3 out of 45 cars had the green/black leather interior
  • 1 out of 45 cars had the red/black leather interior
  • 9 out of 45 cars had a Brilliant Silver exterior
  • 36 out of 45 cars had a Sapphire Black exterior
This vin WDB1240361C056242 have 957 option and doesn't have 958 option.
Where did that VIN number come from? I do not see it mentioned earlier in this thread, nor on the list of VINs with the 957+958 numbers?
This thread specifically deals with only cars with 957+958.
Digging up an old thread, have a query.
A friend of mine owns one of the 45 E60s Limited cars listed above.
The engine number on the VIN does not match the engine number for the engine installed on the car. Could we assume AMG used a different engine for the 6.0Ls or should the engine number listed in the VIN be the correct 6.0L unit? I've asked him to check for the AMG stamp at the back of the engine and will report back.
Eager to hear from other E60 Limited owners to see whether the engine number on the VIN matches the one installed in the car, but appreciate there are not many owners of the E60 Limited on here.
I think the same question would be valid for owners of any code-957 E60's, whether or not they are Limiteds.
IMO, the engine number should match the datacard, if it's a factory build. Even if AMG did a conversion from 5.0L had to replace the block (because late-build cars had open-deck blocks), they would have used a new closed-deck block, and stamped the correct engine serial to match the VIN and original engine.
Yup indeed. My intuition also tells me AMG would retain that engine number on factory delivered cars, but odd stuff happened back in the day particularly when AMG was a tuning house.
Agreed, it should match. Mine matched and it was built/converted as new (even though not 957 code - but original owner ordered it as E60 new other 'unique' things he wanted as part of the build). When I looked to buy/import E60 to US, one of the things I looked for was "original engine number" on the car. Mine is not a Limited (I looked at some 958's and sometimes I really like the interior and other times I decided I wanted regular interior - I eventually went with regular interior), but in any case I wanted to make sure it was the original engine.
The engine number must match! However there are very few hiccups where engine numbers are double posted and requested to be corrected in the internal system once you have such a car. But this is not limited or exclusively on amg variants but also on normal production line mb's. As stated correctly, once a open deck block was replaced by an closed deck version it was re-stamped with the original number.
I can confirm that the Engine number on a factory E60 AMG MUST match the VIN.
If there was a rare case of an engine replacement under warranty or such, it would also be documented in an updated datacard and invoices.
Am I correct in assuming its a Japan import so no documentation is present?
Hallo,
Can someone explain what does this additional text in VIN decoder mean, i csn see that some of you are expert for this so please help:
EIN SCHLIESSZYLINDER 126 460 0204 UND EIN SCHLUESSEL 140 760 0406 WURDEN IN DER NDL KOELN 221/00 VERSCHROTTET.
Record T Text
AUFTRAG PREISLICH ABGESCHLOSSEN.
DLP: EURO 800,00 O. MWST.
LINKS UND RECHTS INCL. GEÄNDERTE KOPFSTÜTZEN:
MICHAEL KLENGEL, FMP/CA,0160-8619007,2010-02-02
AUFTRAG BITTE NOCHMALS AUF RICHTIGKEIT PRÜFEN
PREIS FÜR O.A. MODIFIKATION AN FAHRERLEHNE
FAHRERSITZ LINKS UND RECHTS-AUFPOLSTERUNG
FAHRERLEHNE (20MM KEILFÖRMIG VON OBEN ENTSP.
KOPFSTÜTZEN A2219707450 IN 9F17
43
WDB1240361C206302
It is a misprint at top of the table in post #23 (and following error in post #25), the Limited interior colour codes red and green is switched. Per the EPC it shall be:
  • 286 = Black leather w/red green insert
  • 287 = Black leather w/green red insert
The reason for finding the error is that the only E60 Limited being in Norway WDB1240361C204818 owned by member @Mosselmann, exported back to Germany in 2013 and later on bought by member @Dortmunder, has the 287 red Limited interior:
L'operaio. I knew i had seen that name before. From 1988, and with M117-32V.
#27 (WDB1240361C183327) popped up on the 'Tube today:
Luckily some technician/branch did check on the engine number lately..
Eingetragene Motornummer wurde von R.Kurzen überprüft und ist für dieses Fahrzeug richtig.
DIE MOTORNUMMER DIESES FAHRZEUGS IST AUCH ZU FOLGENDEN FAHR-ZEUGEN HINTERLEGT: WDB1240361C183327 BITTE MOTORNUMMER AM FAHRZEUG PRÜFEN UND GGF. BERICHTIGEN!!!
[th]Record 5 Text[/th]
"Eingetragene Motornummer wurde von R.Kurzen überprüft und ist für dieses Fahrzeug richtig", meaning this engine no. (my guess 009746) is actually built onto VIN 183327..
"The registered engine number was verified by R. Kurzen and is correct for this vehicle.
THE ENGINE NUMBER OF THIS VEHICLE IS ALSO REGISTERED FOR THE FOLLOWING VEHICLES:
WDB1240361C183327. PLEASE CHECK THE ENGINE NUMBER ON THE VEHICLE AND CORRECT IF NECESSARY!"
They should have just deleted the double entry note...also, 99.95% it's a typing error and means actually "vor kurzem" (recently). So the number in the data card matches the vin.
Actually you are both, first right.. and (only maybe..) slightly wrong too :)
- translation of 'vor Kurzem' is 'recently'
- it is (although unlikely!) possible, that an employee at an MB-workshop/facility has 'KurzeN' as surname (and 'R.' being initial for their first-name)
I'm not saying it can't be a typo though.. and about deleting double entry, it would still make somehow sense to check whether WDB1240361C183327 has the engine no. which its data-card indicates too, IMHO
Strangely enough, it's not uncommon to find the same engine numbers on datacards of different vehicles (different VIN's). This is also the case with:
WDB1240361C161822 and WDB1240361C162390 (both showing same engine #'s on datacard ending at 009674), as well as:
WDB1240361C195735 and WDB1240361C202605 (both showing same engine #'s on datacard ending at 010288).
Same with WDB1240361C160617 and WDB1240361C135281 showing identical engine #'s - ending with 009297- on their datacards.
In all these instances, as well as in the above similarity between WDB1240361C165087 and WDB1240361C183327, it might have something to do with the fact that one of "the doubles" is listed as E60 AMG. In other words, something happened with the 6.0 liter drop-in.
In a different situation that is even more strange, the engine # ending at 010241 on datacards of these 2 vehicles seem to be also identical: WDB1240361C204258 and WDB2100551A000266. I have no explanation.
