WANTED Looking for heated seats part
trashtotreasure
Hello was wondering if someone on the boards here can help me with front heated seats heat elements , i'm doing a interior change over from parchment to black , and the front black seats from the 93 300e didn't come with seat heater , any help please , thank you.
The heating elements on the standard seats (300E) have the heaters sewn into the leather cover. They are not available separately - sorry.
If you are installing Sportline 300E seats, the center heating elements are NLA... so you're out of luck there as well.
:runexe:
:runexe:
Thank you very much for the information , is the heating elements from my stock e500 can be re use ? to my black sportline? your opinion ? thank you in advance
If you are installing 300E Sportline sedan seats into a 500E, then yes, you should be able to swap the heating elements. Test them all while apart to make sure none are defective. If the side/bolster elements are bad, you can buy new horsehair pads which come with new elements. Lots of work to disassemble both pairs of seats and swap everything around... if the leather isn't perfect, I'd at least consider new leathers from G.A.T. for $800/set (all four front seat covers plus two headrest covers).
Thank you again sir .
