Last summer I had the transmission pan replaced. I put the car in storage in the autumn and after it sat in the same spot for a while I noticed some trans. fluid on the floor. Just before I put it in storage, it intermittently would refuse to go into 1st gear. Of course, now that it's in storage and can't be started up easily, I can't check the fluid level, which needs to be done with the car warm. My working theory is that fluid had been leaking ever since the pan was changed, and that this somehow caused the reluctance to go into 1st gear, and I'm hoping that addressing the leak and topping it off will cure the 1st gear issue. Am I dreaming?
