Transmission fluid
What is the recommended transmission fluid for sl500 1993?
Dexron II was original spec, ~7.5 viscosity, for all 722.3xx transmissions. Dexron III is the same viscosity and replaced the obsolete Dex-II spec.
(Edited per Gerry's post below.)
Dexron IV can be used, ~6.0 viscosity (thinner), but may need some tweaking of the vacuum modulator if any flare is noticed after the fluid change.
Don't forget to drain the torque converter too. Synthetic is generally preferred assuming the trans doesn't leak.
:strawberry:
How to drain the torque ? Are there two separate drain bolts?
Yup. Converter is drained separately. Need to follow the factory procedure... different size/material seal ring for the converter drain plug... can't refill all 8 quarts at once... etc etc:
Only now do I realize the original spec was for a thicker oil. Makes total sense. Translating old petroleum product spec (oil, trans fluid, tires, speakers, etc) to present day is a science unto itself. Thanks guys,
(Edited per Gerrys post below.)
Dont forget to drain the torque converter too. Synthetic is generally preferred assuming the trans doesnt leak.
:strawberry:
Will strongly caution against using Dex IV in these transmissions. There are warnings that Dex IV is not compatible with the seals in some older transmissions and can over time seriously damage them. Just DON'T DO IT!!! Dex II and III are both fine but Dex IV should be avoided. A much better alternative to DEX IV is the Redline D4.
First indication there may be a compatibility issue was from Allison transmissions and a warning not to use Dex IV because of the seal issue in their units. There is strong evidence that the same issue exists with the seal material used in many older European transmissions. As a result Dex IV use should be avoided in the 722-3 units in our cars.
^^^ where's this from?
I recall talking to 722.3 rebuild specialists about Redline Type F Racing in my rebuilt transmission. And while they warned specifically about other additives in the new box because of the seals, they had no problem with the Type F (which I believe is a DexIV, though I wouldn't be surprised if I was wrong about that).
Which is why I ask where's this from. Thoughts?
Type F = Ford, and lacks friction modifiers that are present in Dexron fluids. Type F generally results in less slippage during shifts, and is desirable for racing use. I've tried Type F in a couple different boxes and I couldn't tell one iota of difference. Might be more obvious on a box that is really worn / slipping / flaring badly. (?)
I would like to know more about the Dex-VI and seal leakage though.
:pc1:
Type F in a couple different boxes and I couldnt tell one iota of difference. Might be more obvious on a box that is really worn / slipping / flaring badly. (?)
Yes, that did make a difference. Before diving into rebuild, I've tried Type-F as that what Jono recommended as a possible "revive/extend life a bit" and it did, made a difference indeed, flaring was decreased by a large margin... Unfortunately mine was too far gone to make it last.
Yes, that did make a difference. Before diving into rebuild, Ive tried Type-F as that what Jono recommended as a possible revive/extend life a bit and it did, made a difference indeed, flaring was decreased by a large margin... Unfortunately mine was too far gone to make it last.
What I’ve noticed is it warms up slower and is more heat resistant down here in the FL heat. I rather like it, actually. Seems shifts are firmer always, but it’s not like I’ve tried any other fluid in a rebuilt box with a new HWA vacuum modulator, so it’s an incomplete experiment at best.
Type F = Ford, and lacks friction modifiers that are present in Dexron fluids. Type F generally results in less slippage during shifts, and is desirable for racing use. Ive tried Type F in a couple different boxes and I couldnt tell one iota of difference. Might be more obvious on a box that is really worn / slipping / flaring badly. (?)
:pc1:
This was the issue with the Allison transmissions.
The main concern surrounding the use with DEX VI in Allison applications is that DEX VI has compatibility issues with some of the seal materials formerly used by Allison. Allison has established serial number cut off’s for use of DEX VI (S/N 6310670488 and up for Indianapolis built transmissions, AND... S/N 6320784373 and up for Baltimore built transmissions used in GM pickups.)
There is also strong evidence that Dex 6 also doesn't play well with the seals in a number of older transmissions. In particular European transmissions. It reacts badly with certain types of seal materials and over time destroys them.
The old Ford type F is a very basic fluid that does not have the more slippery friction modifiers. In fact if you put the wrong fluid in some of the early Ford Autos they will slip badly and burn up quickly. Type F has been used in performance transmissions of every kind because it grabs better and gives a firmer shift for many years. Fluids like the B&M trick shift and Redline racing fluids are basically a modern type F fluid without the more slippery friction modifiers for a smoother shift. There is no issue I know of with running type F in our trans except the shifts may be noticeably harsher.
