Always find your videos entertaining and informative. Keep making them. Happy New Year!
Hi Stephan,
Happy New Year!!!
Keep up the great work.
LoL
Yes indeed, from Las Vegas!!
Nice job, Lowman. [emoji106]
You probably did, but did you check for rust under this part? (Don’t know the name in English)
View attachment 84789View attachment 84790
Had to make this rust-free on my car.
I believe its called the "slam panel"?
Yes the radiator pack was in my way, too. I remember I lifted the pack up an inch or so. I managed to give the steel a good treatment that way. Not the whole “Lowman Treatment” but good enough for my standards.
Keep up the good work! [emoji106]
Indeed ... lowmania is a very real thing on this forum. It lives.
lowmania (noun)
lo·ma·nia \ ˈlō-mā-nē-ə \
Definition of lowmania
1: excitement and elevation of mood manifested by hyperactive and anal cleaning, refurbishment and detailing of decades-old Mercedes-Benz parts to a condition as good as or better than when the car left the factory
// I experienced a serious bout of lowmania last night when working on my 500E.
2 a: an excessive enthusiasm for cleaning and detailing Mercedes-Benz automotive parts, exclusively found only in the western coastal (North Sea) region of Norway
2 b : a Mercedes-Benz automobile that is the object of such anal and peculiar enthusiasm
Lowman you are the man!Your work is amazing as usual. I have pretty similar situation now - the whole front part stripped and I found rust in similar places... Quick question - what is the purpose of the black sponges I marked with red arrow? To me they only retain water and make this place prone to rust... I was planning on skipping them unless they serve some special purpose? Second question - how is the water hose attached to the SLS tank bracket (green circle)? Is this some sort of U style clamp? I'm anal about stock correct details and my car has zip ties all over that place... It makes me crazy. Can you share any more photos of this area and maybe the lower horn if you have any.
The sponges - I thought they are a sort of a cushion for the reflector plastic cowl but are they really needed?
If you could find a part number for that C style clamp - it would be great. The sponges - I thought they are a sort of a cushion for the reflector plastic cowl but are they really needed? Isn't it a little overengineering? I'm still leaning towards removing them from my car and have this place rust free in the future. On a side note - I tried to locate them in EPS but failed - what's the part number if anybody have it in hand?
No problem.I looked today..and i could not see any partsnumber on it...but i "forgot" to check on the "thin side" of the clamp...so i will check that tomorrow.I did not wanna take it off..as i would risk breaking it.heheThank you Lowman.
hey mister.Hi Lowman,
How did the panel look after the sanding? I would have thought 1500 dry sanding is too harsh.
No problem.I looked today..and i could not see any partsnumber on it...but i "forgot" to check on the "thin side" of the clamp...so i will check that tomorrow.I did not wanna take it off..as i would risk breaking it.heheBut i will look again tomorrow.Here is a picture of the placement at least.It is indeed mounted on the bottom of the SLS pump bracket..and i hhave found what can possibly be the part we are looking for..on the Epc..but they do not state the diameter of the clamp..so it is not easy to say if its the correct clamp or not.
Yeah that clamp is interesting, I changed the radiator hose last year and it was held with a wide zip tie that I had to cut. Keep us updated Lowman.
Hey . I tried to press it both waysThank you again for all your efforts. At least your bracket is clean nowI just sand blasted mine and powder coated black. The clamp - well, I will have to live with zip tie style fitting. I'll make it somehow...
BTW this sort of fastening (press in pin style) looks to me identical to some '80 Porsche style fittings. If you want to remove it you have to press the pin from the bottom out, not inside in. Unless you have already tried this way...
And this is my latest work,and i dont care if some of you..or all of you dont like it.I doI always loved this little "Japan mod" detail
So i finally got around sourcing one.
I wetsanded the ashtray wood before continuing on polishing it up to make it shine before adding the sticker.
Really nice work! May I ask where did you get the sticker? Ebay?
Always loved your 16V lowman. Lots of fond memories in my 2.3-16 and your photos would always bring me down memory lane. She's a beauty and I hope going to a good home.
