That generally sounds OK to me. I am not hearing anything in the video that is overly loud or egregious. Sounds like pretty normal M104 noise, to me. Try the heavier oil and see if it calms down that valvetrain noise a bit. I bet it will.
To clartify, WHILE IT IS OK TO USE 0W or 5W engine oils, per the chart I posted, and they are OK to use for all temperature ranges, please notice that for temperatures above 0C / 32F, heavier oils are generally specified. The M104 (as the M117, M103, M119, M120, etc.) generally likes heavier oils whenever possible.
15W-40 diesel-rated oil (which has extra detergents, and which keeps the internals of the engine very clean) is an excellent grade that is right in the middle of the 10W-40 and 20W-50 "sweet spot" for warmer climates where freezing temperatures are not a factor.
If you would like to see the effects of long-term use of 15W-40 diesel-rated motor oil (also rated as acceptable for use in gasoline engines), of the Chevron DELO 400 brand, in an M104, in terms of the cleanliness of the inside of the engine, you can check this forum's M104 Top-End rebuild thread, specifically this post.
Hello @gerryvz
Does the oil need to be mb 229.1 & api sn spec for use on older benz cars?
thanks again.
