M119 bolt torque list?
JC220
Whilst planning on re-assembly of my spare m119 I am wondering is there a list of torque specs available anywhere for the m119 engine bolts?
Aka, a clear 1 stop list. Or must we refer to the WIS sheets for each task in hand?
Eg:
Camshaft bearing cap bolts: 12nm
Camshaft Gear to Camshaft 18nm
Valve Cover bolts: 9nm..............
But for whole engine
I don't know of any 1-stop list. Each spec is separately in each FSM job.
BTW, the cam bearing caps are 10Nm... did you just list 12Nm as a sample?
Dave, firstly I am most disappointed that you dont have such a list on your bedroom ceiling since you are the w124 / m119 god :)
Secondly - AH Ha! Please read the WIS doc again. They are all riddled with errors. The images mostly do not match the table list in the same documents....
So I am using the listed specs rather than the pictures.
Thirdly, I am compiling a list. Just wanted to make sure I wasnt wasting time
Or 10nm for early, and 12nm for late without dowels?
However I am noting issues like this in nearly all WIS docs. Tabled specs don't match the images alot of the time
GOOD QUESTION! I have noticed some inconsistencies as well. I figure anything in the 10-12 range is fine for either with/without dowels. Probably most of us don't have a torque wench calibrated that perfectly anyway.
Now, the most most egregious error I've seen is the ETA bolt spec, which IIRC is 25Nm... for an M6 bolt. Pretty sure this would result in stripping the threads out of the intake manifold. Most M6 specs are ~10Nmn or so. I tighten ETA bolts by hand, to "snug", using new bolts with threadlock pre-applied.
I recently almost tried to torque these bolts to 25NM but it just didn't sound right as small as they are. I went hand-tight too. Plus, I had a thin coat of sealant on both sides of the gasket anyway. Glad I didn't follow the manual on this one.
Note that the gixer will take you off his christmas card list if he finds out RTV has been applied to gaskets - in particular valve cover gaskets :5150:
ESPECIALLY valve cover gaskets. I just replaced these on my wife's E420, where a PO/mechanic used some sealant that looks like chocolate syrup, and dries hard & brittle. I took photos, will post a separate thread on that story. It was a nightmare.
For the ETA, a thin coat of Hylomar sticks the gasket to the ETA so it stays in place while squeezing it through the intake opening. And the Hylomar is easy to remove in the future. Think it's mentioned in the FSM docs too.
:oldman:
Yes. That #%@!
edit; I should not refer to "form a gasket in a derogatory way as it served well for years before there were better alternatives and still has uses such as holding gaskets in place for assembly using tiny dots of the product. Complete gaskets, not a good idea.
drew
These are my draft m119 Torque specs for a wall chart I am creating (Including diagrams from WIS regarding bolt patterns / lengths etc)
Posted for the peanut gallery to proof read and comment / correct on :pc1:
M119 Torque Specs
Camshaft Gear to Camshaft: 18nm
ETA to intake manifold: 9nm
Intake Manifold bolts: Intake Manifold to cylinder head: 28nm. Upper section to lower section intake manifold bolts: 25nm
Exhaust Manifold Bolts: 30nm
Crank Damper centre bolt: Early style 400nm centre bolt. M8 bolts 35nm. Late style =200nm + 90degree
Air Conditioning compressor or guide pulley to carrier: 21nm
Bracket of Air Conditioning compressor to crankcase: 21nm
Timing case cover to crankcase: 21nm
Cylinder head to timing cover bolts: 21nm
Fan Carrier bracket: 21nm
Mounting bracket of Alternator: 21nm
Mounting Plate of Power Steering Pump: 21nm
Reservoir to Power Steering Pump: (Torx) 8nm
Waterpump bolts: 21nm
Air pump bracket: 25nm
Belt Pulley m6 bolts: 10nm
Oil filter housing to Block: 25nm
Oil Filter housing Oil cooler lines: 7nm
Oil Pump centre sprocket bolt: 28nm
Oil Pump to timing case bolts: 21nm
Timing chain tensioner body to block: 25nm
Timing Guide Pin Plug: 10nm
Front upper head covers m8 Bolts at distributer: 21nm
Centre Ignition rotor bracket bolt: 9nm
Flywheel ring gear: 30nm + 90 degrees
Rear crank seal plate to block: 9nm
Upper sump pan bolts to block: M10=40nm, M8=21nm, M6:=9nm
Lower sump pan bolts: 11nm
Transmission Pan bolts: 1st stage – 5nm criss cross pattern. Final stage- 8nm
Transmission Oil Pan Drain Bolt: 14nm
Transmission bellhousing bolts: M12=65nm, M10=55nm
Torque Converter Bolts: 42nm
Comments / criticisms / observations AND ADDITIONS welcome
Hi guys, I just replaced valve cover gaskets on the Renntech. Following Jono's advice, I torqued the valve cover bolts to 10nm instead of 9nm. He thinks that the valve covers have changed their chemistry over the years and require a bit more torque than the book says. I will run it through a few heat cycles and retighten, if needed, later.
Hi guys, I'm in the middle of replacing cam oilers and camshaft advancer's magnets. Could you please let me know what are the correct torque values for those bolts
Hi guys, Im in the middle of replacing cam oilers and camshaft advancers magnets. Could you please let me know what are the correct torque values for those bolts
Most all those specs will be in the FSM... the numbered items above will be somewhere in Group 01 and 05:
Note that bolt #3 (armature) is a single-use stretch bolt that should be replaced. The rest can be cleaned and re-used. Bolts 2 and 4 all need anaerobic sealant when installing to prevent oil leaks.
FSM link:
:jelmerian4:
Thank you for you help. That link which you provided is great
There is plenty of blow by blow on this job here in this thread —
The 126 chassis manual may be online at the 126board.com.
There is no online manual that I know of for the 140 chassis, although there may be some collections of PDF's out there. For the 140 and most other newer chassis you need the WIS.
:matrix:
M119 Torque Specs
Camshaft bearing cap bolts: 10 NM !!!!
