A couple of months ago I posted what evolved into this thread related to an intermittent misfire and what I was doing to try and resolve it. I have finally resolved it but don't think the solution is best attached to that thread.
The problem began a few weeks after I had installed new Bosch caps, Bosch rotors, and Bosch insulators. At an idle only when hot, there was an intermittent occasional misfire. It wasn't a dead cylinder and it didn't fail all the time. I could go for a drive and not have it happen only to have it fail after a few minutes of warming up the next time I drove the car. On more than one occasion I thought the problem was resolved only to have it come back. Dave and others were very helpful.
Other than the new caps, rotors and insulators the following was performed:
- new plugs
- new coils
- new wires
- new vacuum lines to the EZL and the evaporative system
- cooling system pressure test
- running fuel injector concentrate directly into the fuel rail
At wits end and although the caps and rotors only had 175 miles or so on them, I ordered another set of caps and rotors. After installing the caps the problem appears to be gone. Reinstalling one of the replaced caps, brought the problem back! Finally a solution. Here is what I found. Look at the defect 8mm or so to the left of the rotor contact. Other than that flaw, the cap looks perfect and exactly the same as the others yet it causes the intermittent misfire. I'm in the process of returning it to the vendor for a refund.
How to set up ETA to relearn its home postion | M119 Engine
Long story short, on my 500e I've had a misfire at idle after replacing everything in the ignition (Bosch coils, spark plug wires, Bosch caps, Beru rotors, Bosch insulator discs, correct plugs gapped to 1mm). I did a smoke check and found the vacuum line from the rear of the manifold to the EZL...
www.500eboard.co
- new plugs
- new coils
- new wires
