There is a good reason why Chinese-made diagnostic adapters can be purchased for under $10 online.
Inside are only 3 wires! A black, red, white & a jumpered connection. That’s it. All remaining contacts are wide open and empty.
Superficially, the adapter looks ok. 38 numbered pins on one end & 16 contact terminals on the other end. The ends mate up properly to their matching connections. The casing materials also seem correct. But upon closer scrutiny, the cable diameter appears on the small side for supposedly containing up to 16 wires (0.234”/5.95mm) and the item seems a bit too light-weight; it does not present the proper heft as one would expect with a professional diagnostic adapter. This superficiality is all hiding the fact that there really isn’t much substance inside capable of doing the job…how ironically symbolic for this particular time in history, too.
As always, Caveat Emptor!
