Hello everyone. Thanks for sticking with me along this treacherous journey of trying to fix my tick that resulted in a biggest roller coaster of my automotive life from a simple oil change to doing oil tube maintenance to dropping metal into my cylinder head and going to hell and back to fix it
Unfortunately, my phone never picked up the ticking sound enough so that I can share exactly how it sounds, but I stumbled upon a video today where someone had the ticking sound and swapped his oiler tubes and apparently "fixed it" yet his engine ticks just like mine.
If you watch this video at 18:16 the dude finishes the job and pats himself on the back and says he fixed his tick. But clearly as in 18:21 you can hear the ticking audibly from outside the car.
This is EXACTLY how my ticking sounds 100%. So is this just normal? I can hear it from inside the car with the windows up and from outside with the hood closed. Can someone get to the bottom of this? I appreciate all the help.
Summary of work done:
All oiler tubes replaced to aluminum ones with victor reinz o rings installed
oil separator replaced
timing chain guides changed
Does this user have the same problem?
www.500eboard.co
It sounds the same as mine and also mine is coming from the bottom too yet stethoscope on the oil pan reveals no sound.
Ticking / Knock from crank not top of engine. | M119 Engine
So I recently picked up a second merc with a m119. I took it in to my mechainic (a West Berlin mercedes specialist) who rang me a day later and advised me to sell the car. I took the car in because I had what I thought was the ticking sound (the cam oiler issue) and after inspection he said it...
