500E New ETA install - reset procedure?
rucraig
Hi folks. I have a Beckman remanufactered ETA being installed this week. Can anyone tell me the process for resetting adaptation once it's in the vehicle?
Thanks in advance.
Russell
:searchdammit:
OK - the ETA is installed in the vehicle, along with a bunch of new induction hoses and connectors. The good news is that the vehicle now idles
However, bad news is that there is now an ASR light showing, and the car is in limp mode :doh: The workshop says that, following the reset procedure above, the new ETA did nothing - no movement of the butterfly. Possibly connected to the ASR being triggered?
They wonder whether the new ETA is faulty. I hope not - I'm sure Beckman do good work and test units before they're shipped. Their next step is to disconnect the battery overnight and see what happens. If there's no change, they'll plug the original ETA back in to see if the problem resolves itself.
In the meanwhile, I said I'd consult the gurus here. What thoughts do folk have about A) most likely cause(s) of the problem and B) next steps to take to track down the problem?
Russell
The throttle linkage MUST be adjusted properly. Follow the FSM procedure. Make sure at idle, the linkage as completely on the stop on the ETA housing.
Next step is clearing codes on the E-GAS module, and seeing which code returns. That will help identify what is causing the ASR light / limp mode, without guessing.
:asr:
Russell
Many thanks
Russell
Supplementary question - where can I find the FSM procedure?
