Dave, my ignorance is showing...what is "COO" in this context?Hmmm. That is interesting. Usually, the dealer rotors are top-quality units. Was there any COO that you recall on the last set or two of rotors?
Yes, those are the 300x28 standard fronts.
There's a slight chance this was caused by material transfer between pad & rotor, not necessarily that the rotor itself was warped - but it would require measuring runout with a dial gauge to verify.
MB OE pads are known for being very dusty / dirty, which explains what you were seeing.
The only other brand besides Genuine Mercedes that I'd recommend is Zimmerman Coat-Z. Personally, after I had a bad experience with Brembo years ago, I avoid Brembo rotors like the plague.
And I greatly appreciate the piece from Zimm's website on warped discs (or not!). That all makes a ton of sense, though now that I have the car up north for the first time, I do not have anything more than a caliper to measure the rotors' thickness. The bottom line is that when I am firm on the brakes -- not panic stops -- the vibration is beyond anyone would like or find acceptable.
I admit that using standard replacement MB rotors and pads did not give me cause to look for/use a bedding-in procedure. That said, with both sets of new rotors, I was my usually self in braking -- pretty consistent and gentle (I tend to look far down the road for potential trouble), no panic stops, etc. Just didn't happen.
@szvook provided the bedding in for the Porterfields, which I'll follow.
And I greatly appreciate the suggestion for the Zimmerman's -- I had seen them on FCPEuro's site (and Pelican's, I believe) but was unfamiliar with them.
Many thanks, again, Dave.
Bob
