Passenger side tail light doesn't work
kre8tive202
Hello everyone, I am in need of some help. I have a 1992 that when I turn on the headlights, my dash light indicating a bulb is out turns on. I found out that my passenger side tail light was not working. I thought it was just the bulb but after replacing the bulb,still nothing. I put a tester to it and it appears that the tail light is not getting power. All the other lights work...side marker, brake light, reverse and parking light. Is there a fuse for the right (passenger) side tail light (marker) some where. I checked all the fuses under the hood and they are all working. I can jump a power wire to get it working but I want to make it work right. Any help would be greatly appreciated.
Thanks,
Mario
Sent from my iPad using Tapatalk
Thanks,
Mario
Check this recent thread for some quick ideas. http://www.500eboard.com/forums/showthread.php?6124-Small-but-vexing-issue
Does anyone know if a bad headlight switch will cause one of my taillights not to work
If one side comes on, but not the other, I would think no. Maybe try unplugging the tail light and either checking the plug with a volt meter, or plugging in the light panel from the passenger side and seeing what happens.
