How deep is the hole under the oil separator? and which hole do I screw the screw in?Remove the plastic oil separator thingy by screwing in a long, thin sheet metal or wood screw. Then pull out the plastic piece. With that removed, you'll have to get a thin magnet or something to lift out the tip of the hook that broke off.
From memory, the hole is not super deep.... however, I am not sure where the hole goes. And, I don't know if the metal bit would remain captive and unable to go elsewhere - it might, but I don't know.
Good idea. It'll need to be as thin as possible but still magnetic enough. What diameter rod you figure?Magnetize your own recovery tool - small thin steel rod. You need a very strong magnet.
Slide one side/pole of the magnet down that rod in one direction down to the very tip - one direction only. Do this a dozen times ensuring that you are consistent in retracing that same path. Now turn the rod 180 degrees and flip it around, and do the same thing on the other side of the rod but with the other side of the magnet. Repeat a dozen times. To clarify, the first pass you went down one tip of the rod, the second pass you are ending on the opposite tip. Make sense?
That rod should now be magnetized and hopefully thin enough that you can bend it to shape. The strength of the pull is determined on the metallurgy of the rod itself but if your broken piece was also magnetized there should be enough jedi force there to get that piece out.
Yes but I need to see INSIDE the hollow cavity of the cylinder head
@TerryA Why do you like every message on the board by the way? Just curious. Every time I check my notifications I see I have 10 and get excited for replies but then realize it's all TerryA likes on my comments all across the boardPS- Terry’s ‘like’ doesn’t count as a vote. Lol.
It’s just a check off that I read the thread. I read all of the threads as most of the members do.@TerryA Why do you like every message on the board by the way? Just curious. Every time I check my notifications I see I have 10 and get excited for replies but then realize it's all TerryA likes on my comments all across the board.
More lifters than previously. On both cylinder heads now.All the lifters ticking is not good. Are you sure it's all of them, or just more lifters than previously? On both cylinder heads now?
The oil pressure gauge reads from a sensor below the oil filter, but this doesn't measure pressure at the galleys in the head. I can't imagine an oil supply issue affecting both heads simultaneously. I am assuming the oil level is normal (between MIN+MAX on the dipstick). Really not sure what to recommend at this point other than taking it to a competent, reputable shop for additional diagnostics.
I changed the oil to castrol full synthetic 5w40 euro edge just for the hell of it. It was 50% off at the local store. I still get the ticking.OK... that is useful info. If you need a stethoscope to hear the tick, it could be normal operation. Engine internals are not silent. Bad noises are audible with the hood closed. Based on the above, I'd turn up the radio and drive it.
I'd assume you successfully vacuumed out the metal bit, if you couldn't find it afterwards.
