I bought a 1995 e420 (CA model) cheap knowing it needed a wiring harness and eta. i was able to drive it home in limp mode and i even got it to drive a bit without going in limp mode. I rewired the upper engine wiring harness and trottle body. After installing everything the car no longer goes into limp mode but it it undrivable, the fuel shuts off at what seems to be random when pressing on the accelerator pedal. I consitantly am getting pin 7 code 11 Fuel safety shut-off signal to LH-SFI control module (N3/1). While very confident in the engine harness rewire on the eta there was a light green and teal wire I had a very hard time differentiating from one another in their aged state. Would an improperly wired eta cause these symptons? does anyone have wiring diagram for the eta or upper engine harness?
Another concern of mine is after reading and clearing the codes on pin 19 it no longer gives me any blinks. All other pins will give me 1 blink for no codes, is this ok?
How can I use the led blink reader that comes on CA models that is located forward of the computer module box?
