Question for you ABC guru's - 05 S55 AMG pulsation dampner
alabbasi
Mercedes Flopper
All, my 05 S55 was recently rear ended, it was not a hard hit but managed to rock the engine enough to crack the neck on the pulsation dampner. We took it apart yesterday and found the following:
The impact caused damage to the pulsation dampner which cracked at the neck and also broke the bracket where the ground strap is attached (not sure what the part is called and where it attaches to on the other side).
Can anyone help me with part #’s for these parts?
I can’t seem to locate the part number for the bracket and it’s not clear to me from the parts diagram whether the pulsation dampner is part of the hole or a unit by itself. I do not see a part # on epc for it standing alone.
I'd also be interested in seeing a better picture of that broken bracket if anyone recognizes it, and how it attaches
Al, have a look at the attached. Some of the WIS references (or the TSB itself) may be of use to you -- the "Remove and Install" references may show you part numbers. Your third attachment looks a bit like Part 15 on this diagram, but I can't quite make it out. I'll poke around my files to see if I have anything else more directly on point. Hopefully Jono chimes in because I'm sure he knows or has WIS access and can figure it out quickly.
P.S. update here, one of the best ABC resources I’ve seen... ABC System
