I own a 1992 500E, 177000km,, had it for two years ,only drive it in the summer months when I am home,, so that's about 4000km a year,,
I have this very annoying thump or bang noise from the rear end when i drive over cracks in the road,, roads are not the best where I live,, lots of cracks in the pavement,,
Anyway,, I have checked the trunk,, space tire,, exhaust system,, suspension bushings,, and just replaced the accumulators as per what I have read on this site,, but the thump is still there, I even rode in the trunk to see if I could pin point where it ( the thump) is coming from.
It appears to be coming from around the outside end of the rearend aorund the Hyd shock absorber,
Have changed the rims and tire from originals to 17" Evo six spoke with Goodyear Z1 allseason low profile tire,, which may be part of the problem????
Does any one have information on this problem or has it happened to any of you and what are your suggestions to fix it...( install a big loud stereo unit in the car)) Ya it's coming...
Need help with this..
Thanks,
Bob
Thanks,
Bob
Replacing all the rear links and bushings cured similar noises for me...your mileage indicates you are about due anyway. Try that if you don't the problem in the rear struts.
