Rear speakers dead - any ideas?
Matin
Hi guys,
Just wondering if anyone has knowledge about the speaker systems..
The front two speakers work fine (no speakers in the doors), just the rear is dead. - I have an aftermarket head unit made by Alpine.
Any ideas before I start ripping stuff up?
Car is a 1992 500E
Cheers
Is the centre fader switch still in place? It’s a dial type switch near the gear selector. Try moving it back & forth to see if anything changes.
Since you say the car has an aftermarket head unit fitted I would start by pulling it out & taking a look at the wiring. In most all cases it will have been hacked up to fit the aftermarket radio. Chances are that’s where the problem lies. Also take a look under the rear parcel shelf inside the boot to check that the speakers look original & have the wires connected.
People are supposed to use an adapter harness when fitting a radio but as I say any car I have had there is always terrible wiring waiting behind the radio. I normally buy a new ISO plug & solder it into place tidying all the wiring up as I go. That way any other radio install will be easy – just plug it in.
Conversely, should you wish to install a Becker Unit or similar now would be the time to make that choice as you will then want to re-instate the original type radio plug.
Joe - thank you, thank you, THANK YOU! I totally forgot about the fader switch, moved it around and the rears started working again! Saved me tearing everything up.
I bought some new Rainbow speakers, so I'll fit them in on the weekend!
thank you again
Matin
