Showcase your homebrew MB related tools in this thread
R129 UK
R129 Infidel
Inspired by the "What’s your best buy DIY garage tools?" thread here.
I thought it would be an idea to have a place to show off any MB special tools you have made or adapted yourself for a particular application.
Often, special MB tools listed in the technical documentation are NLA or expensive and a bit of ingenuity can create a workable alternative.
My first contribution is a set of M119 camshaft pinning tools MB part number 111 589 03 15 00:
Really simple to make and could be made with M6 studding and threaded collars instead.
The centres of the pins is ~138mm but they are fully adjustable.
Tool 3 is for electrical diagnostics, specifically finding a known parasitic current draw or checking the current draw of a circuit for troubleshooting:
Cut the fuse through the centre section between the blades and solder a test lead to each side which can be connected to a Multimeter in series.
My DVM has 20A over current protection. This device should not be used to fault find an unknown issue causing a fuse to blow as it could introduce much greater current than the components can withstand.
The same principle could be applied to torpedo fuses I think.
I’ll play.
First, my very crude tool to R&R the fan when replacing the fan clutch. $8 worth of steel from the big box home store and some lousy welds.
And second, my custom shift bushing installation pliers made from the cheapest vise-grip style pliers I could find, a large washer and a 1/4” flange bolt.
