Shifts up from 3 to 4 are absolutely normal and kickdown works as it should on 3-4.
1 and 2 however are "off". Mat it from a say 20 MPH roll car will hit 1st but will bounce off the limiter before shifting to 2nd. 2nd however at WOT will shift early at around 4200 so?
The ist to 2nd shift may be low fluid as I'm right at min hot but that low 2/3 shift does not make sense??
Hit it at speed( say 70 or so) and trip the kickdown switch 3rd will shift right at redline exactly where it should.
Now in normal driving everything seems to function as it should but at WOT and kickdown engaged is nutty. One question I do have is where should the trans upshift without the kickdown from 2 to 3 at high throttle? Will shift at 4200 or so now no matter if into kickdown or just under so??
Replaced the switch at the floorboard today but wonder if that relay which controls the gear hold could be the problem as it is unique to the 420. Time will tell if the cold hold issue returns as temps right now are well above when that issue surfaces.
