FYI, following up on this post from @gerryvz:We will be taking the forum off-line on Saturday, Feb. 3 at 8:00 AM EST for approximately one hour.
During this time, we will be applying TWO forum software patches — XenForo 2.2.14 Patch Level 2, and then XF 2.2.15 on top of that.
Also, we will be updating the php language version from php 8.1 to php 8.2. This is downloaded and already on the server, as is the brand-new php 8.3, but we have to flip the version pointer from 8.1 to 8.2, and then run some quick tests on the forum and various add-ons, to make sure that nothing breaks.
We are being told that there will be one more, final XenForo 2.2.x version published in the next couple of months, and XenForo 2.3.0 will be released also like in or before this spring.
XF 3.0 is under full-time development, but I am not expecting this to be generally available until well into 2025.
Hello GerryZ - this is off the subject but I saw a reply of yours that indicated you could find VIN numbers from an Engine serial number - I bought someone's unfinished Kitplane project and it has a Honda Engine adapted by Viking Aircraft company - they used to have a carfax on the car it came out of but they lost it - the engine serial number is L15B7 2045504 it is a 1.5 liter turbo charged VTC out of a Honda Civic probably earlier than 2018 - I would really appreciate your help or a direction you might send me - Sincerely Jim G.I wanted to let folks know that I will be taking the redirect system down for a few hours, likely tomorrow (Thursday) morning from about 5-8 AM Eastern Time. This is to do some further migration of remaining photo albums from the old site over to this site.
During this period, links to posts on the old forum will NOT redirect to the appropriate post on this site. I am trying to do this at a time when few people will be using this site, so the impact should be minimal. ALL content existing on this site will continue to be available, you can post/reply, and so forth, during this time.
Thanks for your patience while I make this final push to get the Photo Albums migrated.
I have 53 photo albums yet to migrate or delete. I believe up to two-thirds of those albums were deleted by their owners, but I need to double-check them (one at a time) against the records on the other site.
Sadly, we are only able to do this with Mercedes engines/VINs, pertaining to the 1991-1995 500E and E500 models. We don't on this forum really deal with other Mercedes models extensively, nor do we deal with non-Mercedes automobiles, engines or technology at all.Hello GerryZ - this is off the subject but I saw a reply of yours that indicated you could find VIN numbers from an Engine serial number - I bought someone's unfinished Kitplane project and it has a Honda Engine adapted by Viking Aircraft company - they used to have a carfax on the car it came out of but they lost it - the engine serial number is L15B7 2045504 it is a 1.5 liter turbo charged VTC out of a Honda Civic probably earlier than 2018 - I would really appreciate your help or a direction you might send me - Sincerely Jim G.
The Wiki update went south, due to a bug in the new version that borked the upgrade process. I contacted the developer, and he provided me with a fix.We will be updating the Wiki software today around 5 PM EST.
The Wiki will likely be down (non-visible per the menu-bar item) for 5-10 minutes, but the rest of the 500Eboard site will not be affected.
I have an updated fix from the developer, and will code it a bit later today / tonight. We’ll see how it works…..The site's Wiki is back up and running just fine, but it is using the previous version of the software. The fix that the developer provided, as well as an updated version, are both not working.
Thus, I reverted back to the previous, working, version. I should have a new fix to attempt, in the next 1-2 days. Fingers crossed.
Wiki has been successfully updated with the new code, and should be working fine now.I have an updated fix from the developer, and will code it a bit later today / tonight. We’ll see how it works…..
It's been a few days now, with zero issues with the forum sending out e-mails again. I'm going to call this problem SOLVED.It does appear that email is back to flowing as it should, and no Google-related authentication errors have been thrown in the past hour. We were getting 100+ error messages per hour over the past day or two....it was getting overwhelming !!
Just starting getting this error when I try to upload any image:
Oops! We ran into some problems.
ErrorException: [E_WARNING] fopen(/home/500eboard.co/public_html/forums/internal_data/attachments/216/216942-7f4ecedff785ed7a8d1ce56b9a685321.data): Failed to open stream: Permission denied in src/vendor/league/flysystem/src/Adapter/Local.php at line 157
- XF::handlePhpError()
- fopen() in src/vendor/league/flysystem/src/Adapter/Local.php at line 157
- League\Flysystem\Adapter\Local->writeStream() in src/vendor/league/flysystem/src/Filesystem.php at line 122
- League\Flysystem\Filesystem->putStream() in src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php at line 430
- League\Flysystem\EventableFilesystem\EventableFilesystem->callFilesystemMethod() in src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php at line 395
- League\Flysystem\EventableFilesystem\EventableFilesystem->delegateMethodCall() in src/vendor/league/flysystem-eventable-filesystem/src/EventableFilesystem.php at line 71
- League\Flysystem\EventableFilesystem\EventableFilesystem->putStream() in src/vendor/league/flysystem/src/MountManager.php at line 615
- League\Flysystem\MountManager->putStream() in src/XF/Util/File.php at line 216
- XF\Util\File::copyFileToAbstractedPath() in src/XF/Service/Attachment/PreparerService.php at line 89
- XF\Service\Attachment\PreparerService->insertDataFromFile() in src/XF/Service/Attachment/PreparerService.php at line 49
- XF\Service\Attachment\PreparerService->insertAttachment() in src/XF/Attachment/Manipulator.php at line 197
- XF\Attachment\Manipulator->insertAttachmentFromUpload() in src/XF/Pub/Controller/AttachmentController.php at line 95
- XF\Pub\Controller\AttachmentController->actionUpload() in src/XF/Mvc/Dispatcher.php at line 362
- XF\Mvc\Dispatcher->dispatchClass() in src/XF/Mvc/Dispatcher.php at line 264
- XF\Mvc\Dispatcher->dispatchFromMatch() in src/XF/Mvc/Dispatcher.php at line 121
- XF\Mvc\Dispatcher->dispatchLoop() in src/XF/Mvc/Dispatcher.php at line 63
- XF\Mvc\Dispatcher->run() in src/XF/App.php at line 2826
- XF\App->run() in src/XF.php at line 806
- XF::runApp() in index.php at line 23
This should be now fixed. It was a permissions issue on the server, relating to the folder that contains all forum images.confirmed. On it.
Typical teething problem with the switchover to the new forum software and server.
Should have a fix very soon.
Thanks for flagging.
OK folks, here is the promised technical update.I will be providing a general technical update this weekend, now that the migration to the new server is complete.
Here is a little information on the site backup regimen and redundancy that we have, so that site information is not lost.We also had to re-set-up many automated tasks from the old system, such as the daily and weekly database backups, administrative accounts on the server that performed these tasks, and re-do various security settings. All of this "post-migration" work has taken about 12 hours to complete.
cron command. A "cron" job is basically a timer that triggers the system to do a specified task at a given minute, hour, day, or month. Basically you can do anything under the sun on a system with a cron job.
rsync (Remote Sync) command, which compares the local files on my hard drive to those on the server, and downloads any new files to my home computer, and/or deletes any files on my home computer that were deleted on the server. This process takes about 3-4 minutes to complete.
facl command, which pertains to “access control lists”. ACLs are specific permissions that allow specified users to access directories and directory hierarchies (folders and files within a directory). @bclifton knows all about this stuff, I’m 100% sure.
