I can't believe I missed this thread!
Regarding 92 ECUs, I think that "fixed" amount of fuel that it is providing in open loop is still based on what it is providing in closed loop. I don't believe it is a set in stone figure, but rather a figure that is based on a simple percentage increase over whatever the ECU was providing under closed loop conditions. After the ECU has adapted to one's breathing mods, it will now base it's new open loop WOT fuel enrichment on those new parameters.
Rather than replacing 93-94 ECUs with 92 ECUs, RENNtech probably just used what they already had, since they had to reprogram them anyways. (And since even 92 ECUs would also have had to been reprogramed too.)
Stevo Devo needs to weigh in on this. I do believe his stock 92 ECU has been re-flashed.
Regards,
Eric
4) If you add headers, port the heads or manifolds, etc, etc... anything to drastically change the airflow... the LH module will adapt to the change in airflow automatically, over time. You can view (and reset) the adaptation values with a digital scanner, for lower- and middle-RPM-range operation. The system doesn't display WOT adaptation. With a heavily modified engine, it's likely that the 93-94 LH module is more desireable, since it will stay in closed loop, and keep providing fuel to maintain 14.7 ratio at WOT. The 1992 module can't do that, it still sends the same fixed amount, even if there's more airflow. Note that RENNtech's 6.0L M119.97x engines use 1993-94 modules with a custom EPROM.
5) I don't think we'll find any easy re-flashing, because someone would need to download the stock programming (and maybe the eBay, RENNtech, or Superchips programming) and compare them, then modify the program. The problem is, almost nobody knows how to do this for the LH systems used in our M119's. This is way, way beyond any DIY tweaking. And, I firmly believe that there would be minimal power gains anywhere in the powerband... and if there were, it could come at a significant penalty in fuel economy (or perhaps even damage the catalysts).
Regards,
Eric
I love a happy ending. Thanks for the update!
Me too !!
). I was looking to see IF a chip would help things in that mid range torque normal driving realm and guess not. Frankly I find I am driving my Volvo around town more simply because the 190 horse 6 cylinder Volvo ( which weighs about the same as the 420 BTW) is a LOT more responsive in normal driving and more fun to drive in traffic. Like I said get the 420 on the highway and things reverse in a hurry but around town in normal driving say at about a 30MPH or so roll on the 420 is a real dog in response unless you hit it hard enough to kick it down.
